Leaking Frost Free Sillcock - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-10-2011, 07:51 AM   #1
Unhappy
I have a frostfree sillcock that leaks from the cap on top from the time I turn it on utill I turn it off. The shut off valve works fine. Is there a kit or adjustment I can make to stop the leaking from the cap short of replacing the sillcock?
wjnwalt1 is offline   Reply With Quote
Old 06-10-2011, 08:47 AM   #2
Civil Engineer
Rewards Points: 4,518
I have never seen a fix it kit for a frost free sillcock. My frost free one has a whole set of instructions that explain, curiously, how critical it is to remove the hose from the sillcock during freezing season, else they explain that the sillcock will leak, and will need to be replaced. They also explain that it is necessary to pitch the sillcock backwards towards the house during installation, else the sillcock was prone to freezing. I guess they are semi-frost free. In any case, the instructions specifically stated that if the sillcock leaked, you had to replace it.
Daniel Holzman is online now   Reply With Quote
Old 06-10-2011, 09:54 AM   #3
Thank you for your quick response. I'll replace the faucet.
Help My Admiral Refrigerator is leaking water Cuwillis Appliances 10 03-25-2014 09:21 AM
Frost Free Sillcock Brands? BigD9 Plumbing 7 06-23-2013 10:32 PM
good frost free sillcock brands? debiasio Plumbing 5 08-18-2010 01:03 PM
frost free sillcock jmacp Plumbing 2 07-01-2010 07:36 PM
Frost free sillcock white29 Plumbing 5 04-29-2008 11:38 PM
