Leaking Faucet..replaced Cartridge - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-28-2012, 07:13 PM   #1
Leaking faucet..replaced cartridge
We had a leaking tub faucet and I replaced the cartridge and the little rubber/spring thingy combo that stopped the leak.Problem is, the faucet now has to be turned in the opposite direction as before to turn the hot water on.
1.What did I do wrong?
2.What is the fix?
Thanks!
mrmerck is offline   Reply With Quote
Old 03-28-2012, 08:45 PM   #2
Oh. I know this one.
You need to rotate the cartridge 180 degrees.
Rewound98 is offline   Reply With Quote
The Following 3 Users Say Thank You to Rewound98 For This Useful Post:
jaydevries (03-28-2012), plummen (03-29-2012), VIPlumber (03-28-2012)
Old 03-28-2012, 09:23 PM   #3
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Depends on the cartridge. Some can be rotated if it's a single handle.
If it's a 2 handle, sometimes you have to get a cold or hot to replace the corresponding cartridge.
From what you describe, it sounds like a delta 2 handle. Check the bag and see if it says hot or cold on it. I'm not sure those cartridges can be rotated.
Journeyman Plumber
The Following User Says Thank You to Alan For This Useful Post:
how to recognize the new or old bathtub faucet cartridge jeand Plumbing 2 12-18-2010 01:27 PM
shower faucet valve leaking throne7 General DIY Discussions 6 03-13-2010 06:31 AM
2 faucet shower control - Hot H20 leaking John24689 Plumbing 5 10-28-2009 04:44 PM
Shower Faucet Leaking NightOfDiscovery Plumbing 2 08-17-2009 10:58 PM
Cartridge stuck in a Kohler faucet Fan in Exil Plumbing 5 05-15-2009 11:53 PM
