Leaking Drainage Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-30-2010, 10:03 PM   #1
Question
Leaking drainage pipe
This just started leaking last week, each night the bowl is filled with clean water. I tried to tighten the 2 metal screws however that did not help. I am unable to see if there is a crack, but I think it may be that the rubber piece making a tight fit is old and worn out. What should I do?
Pic:http://skitch.com/kopac07/nh134/dsc00024.jpg
kopac07 is offline   Reply With Quote
Old 03-30-2010, 11:23 PM   #2
Rewards Points: 328
first watch it while somebody runs water and find out exactly where it is leaking from
plumberinlaw is offline   Reply With Quote
Old 03-31-2010, 03:36 PM   #3
Seems like the leak is coming from the bottom where the rubber piece is.
Water leaking through copper pipe. willowgirl Plumbing 10 01-17-2010 06:29 PM
The IPGC Drainage Pipe agster97 Landscaping & Lawn Care 0 07-09-2009 01:05 AM
Building a soffit around a drainage pipe along the wall ssudha17 Building & Construction 12 10-04-2008 04:18 PM
Heavy-duty roots in ground drainage pipe proofer Plumbing 11 08-06-2008 05:42 PM
Leaking PVC Pipe kennykenny Plumbing 8 12-26-2007 09:53 PM
