Leaking Drain Pipe Under Kitchen Sink - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-22-2011, 06:12 PM   #16
Plumber
TheEplumber's Avatar
Rewards Points: 452
That looks purdy
I'd hate to tell you the 1 minor code violation so I'll keep my mouth shout.
How'd you get the pipe out?
Old 03-06-2011, 02:08 PM   #17
I am sorry for not responding sooner. My computer crashed shortly after I fixed my kitchen drain pipes so I have been busy trying to get my pc up and running. Needless to say, I am not a computer guru or a plumber!
I extracted the pipe by using a big wrench and twisting slowly (so slow it took days to loosen the @#@!!* - I just worked a little each day) and I was very patient and gentle. I can only attribute my success to some miracle force - I am not that gifted.
I have to ask: what is the violation? Please pretty please tell me. I am a glutton for punishment
dethun is offline   Reply With Quote
Old 03-06-2011, 02:12 PM   #18
you can only have one slip nut past the trap to connect the white stuff to the pipes in the wall. to do it right, you'd need to extend the pipe from the wall with pvc/abs and connect your trap to that, using just the single slip nut. but like eplumber said, it's not a big deal
the_man is offline   Reply With Quote
Old 03-07-2011, 11:25 AM   #19
Thank you for your response. I will likely end up fixing the pipe to get up to code (it drives me insane to not do things right), but it will be awhile before I walk that plank. I am sure when I do, I will be logging back on to this site to beg for help. Until then (or until my work of art starts to leak - whichever occurs first) I will enjoy my kitchen sinks and being able to wash my dishes without having to take a bath at the same time There is just something about taking a bath with dirty dishes that just doesn't work for me...
Old 09-26-2012, 07:11 AM   #20
Rewards Points: 334
For future reference (and maybe not to code !).
I was faced with helping someone else with a similar problem, but the previous owner ruined the threads with so a new pipe could not be inserted, I found a no hub adapter that fit over the T in the wall to something that accepted the tail piece. (I think it was 2 inch x1 /1/2).
tribe_fan is offline   Reply With Quote
Old 09-26-2012, 08:30 AM   #21
Rewards Points: 1,570
Dethun,
Congrats! Looks very well done!
bob22 is offline   Reply With Quote
Old 03-12-2016, 10:21 PM   #22
I'm in desperate need of assistance with a very bad leak under my kitchen sink. The leak is coming from the metal pipe that attaches to the PVC pipe. I took the PVC pipe apart and the metal pipe has a hole in it. It looks like it might be possible to unscrew the metal pipe, but since this is the first time I've ever touched anything plumbing wise, I am afraid to proceed without advice. I can't afford to pay anyone to help me. I have a video and some pictures, I'll see what I can post. I appreciate any help anyone can give. Thank you so much!
Leaking drain pipe under kitchen sink-img_20160312_212336_1457839482597.jpg   Leaking drain pipe under kitchen sink-img_20160312_194311671_1457839660783.jpg
Urmy is offline   Reply With Quote
Old 03-13-2016, 06:53 AM   #23
Rewards Points: 220
Re: Leaking drain pipe under kitchen sink
Welcome to the forum urmy.
It's best to start a new thread of your own instead of piggybacking off a 5 year old thread, you will get better results. Members will see it's an old post and move on.
It will be tricky, but can be done. Stop flushing grease and chemicals down your kitchen sink, your pipes will last longer.
jmon is online now   Reply With Quote
Leaking connection between disposal pipe and drain pipe in kitchen geniusintx Plumbing 1 07-06-2010 05:14 PM
Kitchen Sink Waste Pipe... Help! AZLambdaK1 Plumbing 7 06-20-2010 02:20 PM
Drain Pipe about 20 Inches to the right of Vanity Sink mark2741 Plumbing 2 12-16-2009 11:32 AM
Sink drain for new sink. Can't get to plain pipe. rogersmithiii Plumbing 2 07-10-2009 11:24 AM
drain pipe size for kitchen sink, garbage disposal, and dishwasher ? amakarevic Plumbing 5 08-05-2007 01:23 AM
