Leaking Drain Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-17-2012, 03:44 PM   #1
Leaking Drain Pipe
I have a leaking drain pipe behind the foundation. I'm wondering if I can cut the floor joist enough to get some pipe repair tape around this. I'm attaching pictures.
Leaking Drain Pipe-img_20121117_142025.jpg   Leaking Drain Pipe-img_20121117_141938.jpg
dschuemann is offline   Reply With Quote
Old 11-17-2012, 05:07 PM   #2
Rewards Points: 13,260
That old steel pipe needs to be replaced with PVC not repaired.
At some point it always leaks and plugs up from the inside out.
Old 11-17-2012, 05:11 PM   #3
Any suggestions to get to the pipe with the floor joists in the way or do they make some stop leak stuff like with radiators?
Old 11-17-2012, 05:15 PM   #4
What's on the back side of that wall?
Old 11-17-2012, 05:21 PM   #5
I think its dirt. That wall is the foundation.
Old 11-17-2012, 05:25 PM   #6
Then what is this pipe draining?
What"s the other end attached to inside?
Trying to figure out if this is suppost to be a drain how is water running up hill from inside the house?
Old 11-17-2012, 05:39 PM   #7
It is the drain from the sink. It drains from the sink goes down this pipe back into the house and out the sewer line.
Leaking drain pipe under kitchen sink dethun Plumbing 22 03-13-2016 06:53 AM
Replace brass drain in lead pipe hercules2424 Plumbing 2 08-09-2011 01:28 AM
drain pipe from HVAC in attic dripping on to sheetrock gnostic19 HVAC 7 03-22-2011 04:05 PM
Tap 2" Drain Pipe into 4" PVC Main Sewer Drain Pipe brmatthews Plumbing 3 12-20-2010 08:49 PM
AC Coil drain pipe questions fritzycat1 HVAC 14 11-12-2010 04:51 PM
