-   -   Leaking Drain Pipe (http://www.diychatroom.com/f7/leaking-drain-pipe-163693/)
dschuemann 11-17-2012 03:44 PM
Leaking Drain Pipe
2 Attachment(s)
I have a leaking drain pipe behind the foundation. I'm wondering if I can cut the floor joist enough to get some pipe repair tape around this. I'm attaching pictures.
joecaption 11-17-2012 05:07 PM
That old steel pipe needs to be replaced with PVC not repaired.
At some point it always leaks and plugs up from the inside out.
dschuemann 11-17-2012 05:11 PM
Any suggestions to get to the pipe with the floor joists in the way or do they make some stop leak stuff like with radiators?
joecaption 11-17-2012 05:15 PM
What's on the back side of that wall?
dschuemann 11-17-2012 05:21 PM
I think its dirt. That wall is the foundation.
joecaption 11-17-2012 05:25 PM
Then what is this pipe draining?
What"s the other end attached to inside?
Trying to figure out if this is suppost to be a drain how is water running up hill from inside the house?
dschuemann 11-17-2012 05:39 PM
It is the drain from the sink. It drains from the sink goes down this pipe back into the house and out the sewer line.
