Leaking Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-16-2013, 08:32 PM   #1
leaking drain
extension tube joint leaking under sink; new 1 1/4 x 6' tube; have tried dousing nylon ring with WD-40 but still leaks. recommendations?
milanoml is offline   Reply With Quote
Old 05-16-2013, 09:20 PM   #2
DIY staff
Rewards Points: 7,174
Check for a flawed nylon ring---also feel for burs or ridges on the tube or mating surface---scrape them off with a sharp knife---
Make sure the nylon ring is facing the right way--thick side to the nut---
Old 05-16-2013, 09:56 PM   #3
Master Plumber
Javiles's Avatar
Rewards Points: 990
Wd 40 ??
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 05-16-2013, 10:08 PM   #4
DIY staff
Gray tape and WD40, a pair of Vice Grips and you could fix an airplane!!!
Connecting shower drain to toilet drain Liv Plumbing 10 04-17-2013 11:53 PM
Rusted and almost gone drain pan, Package unit Nordyne kilosos2 HVAC 3 11-18-2012 10:24 AM
Leaking bathroom sink drain - how to fix? thinksincode Plumbing 11 02-22-2012 10:34 PM
Drain hose leaking supermex79 Plumbing 4 05-17-2011 08:19 AM
Furnace leak while running AC unit lbartowski HVAC 3 09-18-2009 02:46 PM
