-   -   leaking drain (http://www.diychatroom.com/f7/leaking-drain-179745/)
milanoml 05-16-2013 07:32 PM
leaking drain
extension tube joint leaking under sink; new 1 1/4 x 6' tube; have tried dousing nylon ring with WD-40 but still leaks. recommendations?
oh'mike 05-16-2013 08:20 PM
Check for a flawed nylon ring---also feel for burs or ridges on the tube or mating surface---scrape them off with a sharp knife---
Make sure the nylon ring is facing the right way--thick side to the nut---
Javiles 05-16-2013 08:56 PM
Wd 40 ??
oh'mike 05-16-2013 09:08 PM
Gray tape and WD40, a pair of Vice Grips and you could fix an airplane!!!
