Leaking Double Check Valve Assembly (Watts) - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-07-2009, 06:52 AM   #1
Just call me Andrew
Rewards Points: 1,020
Leaking double check valve assembly (Watts)
I had a 007-M1QT 1" double check valve assembly installed by a licensed plumber for a lawn sprinkler system. It is installed outside, above ground.
We turned it on and there were no leaks, the water just shot out of the outlet of the 007 like it should. We then shut the water off for a couple weeks.
I attached a few more fittings (union, Tee, etc) then attached it to the sprinkler manifold in the ground.
Now, when I turn the water on, water shoots out of the test cock on top of the 007 (The one on the raised platform/cover - between the two check valves).
We did not touch any screws or settings on the 007 other than turning the valves on/off. What could cause the water to come out of this spot, and not simply flow through the valve like it did before.
I tried opening the boiler valve that I installed after the 007 to release the pressure, and the water still shoots out of the test cock on top of the 007 cover. Thanks.
I have attached a picture to show where the water is shooting out.
Thanks.
secutanudu is offline   Reply With Quote
Leaking pressure relief valve Chris Magee Plumbing 12 08-12-2008 07:48 PM
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 12:43 PM
Sewage Lid + check valve majorchamp Plumbing 2 07-07-2008 10:06 AM
Jackel Eco Systems DJ-545 check valve pesphoto Plumbing 5 05-20-2008 08:49 PM
DIY electrical work questions for finishing a basement. mac41099 Electrical 7 11-16-2007 07:59 PM
