Leaking Connection Between PVC Drain And Cast Iron Trap - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-14-2011, 10:48 AM   #1
Leaking Connection Between PVC drain and Cast Iron Trap
Hi there,
We moved into a 1953 ranch this summer. The kitchen was remodeled sometime in the 80s or 90s, and much of the undersink plumbing was replaced with PVC. The connection between the PVC and the cast iron trap is currently leaky. Since this is our first house, we've been constantly learning--what's the best way to fix this problem? It looks like this:
Thanks,
Jen
sleepyjen is offline   Reply With Quote
Old 11-14-2011, 11:43 AM   #2
Rewards Points: 338
unscrew it, there should be a beveled plastic washer between the plastic and cast iron. it is probably cracked or damaged and needs replaced.
NitroNate is offline   Reply With Quote
replacing cast iron pipe davemarz Plumbing 1 05-20-2011 10:16 PM
removing Cast Iron drain pipe jimmyfloyd Plumbing 1 01-04-2011 04:47 PM
Cast iron floor drain trap cdjackson Plumbing 1 12-01-2010 05:39 PM
Leaking cast iron drain pipes + roots in 4" main line aminus21 Plumbing 5 09-25-2010 11:21 AM
floor drain / cast iron to pvc? n2learning Plumbing 3 08-01-2010 07:20 PM
