Leaking Compression Fitting On Main Water Line - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-26-2012, 06:29 PM   #1
Leaking compression fitting on main water line
I have a lawn sprinkler system and have discovered a leak in a compression fitting in the main water line at the tie in to the sprinkler line. I have taken the nut loose and cleaned the threads, retightned the nut but still have the leak (drips about each second). There is no play in the pipes to remove the fitting. What's the next best step?
harrison8772 is offline   Reply With Quote
Old 04-26-2012, 06:33 PM   #2
Rewards Points: 13,446
Most likly someone over tightened it.
Once you do it's trash.
Might be a good idea to let us know what type pipe it is for better suggestions.
Old 04-26-2012, 07:02 PM   #3
That's not what I wanted to hear. I have attached three pics of thee pipes, connection, etc. The compression fitting is on the main connected to a "t" which goes into the main shutoff valve for the sprinkler. As you can see there is not much room to work. Looks like more digging, cutting and splicing.
Let me know if any more information would help.
Thanks.
Old 04-26-2012, 07:09 PM   #4
Not sure why they used a compression fitting.
Just cut it out and use a reguler elbow, a few short pieces of new PVC and two repair couplings. Repair couplings do not have a hub in the middle of them so they can be slid over the pipe.
Old 04-26-2012, 07:19 PM   #5
It's not really an elbow. It's a "t" with the line continuing to the house. The 90 degree goes to the main sprinkler shutoff valve.
Old 04-26-2012, 08:33 PM   #6
Rewards Points: 582
dig it out alittle more remove leaking fitting replace it...use glue up not compression.....will get better job..
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Inline water filter for built-in fridge (water supply line on top) Druidia Appliances 5 03-10-2012 12:05 AM
Main Water Shutoff Valve Inside leaking kentifur Plumbing 6 11-03-2011 07:16 AM
Leaking water line needs new water regulator? huynh Plumbing 16 11-04-2010 11:32 AM
leaking water main LanterDan Plumbing 4 08-31-2006 07:24 AM
