Leaking Cold Water Tank - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-12-2012, 04:13 AM   #1
leaking cold water tank
Hi We seem to have an intermittent leak from our cold water tank. Only happens once every few months. Do you think it could be the ballcock?? Any other suggestions?? Thanks
rosie11 is offline   Reply With Quote
Old 05-12-2012, 07:50 AM   #2
Rewards Points: 1,548
Are you sure it is not condensation on the outside, which will be greater if the room air is more humid?
Is this a sealed tank like a pressure tank, or an top opening tank like a cistern?
Old 05-12-2012, 09:12 AM   #3
It's an open top tank. Don't think it's condensation. Too much water for that. Thanks
Old 05-12-2012, 09:37 AM   #4
Rewards Points: 14,290
Your there looking at it, were not. Not sure how anyone here could tell you were it's leaking.
Old 05-13-2012, 09:20 AM   #5
biggles's Avatar
feed supply swetting when it fills on a humid day leaks don't go on/off only get worst...is it water on the floor or running leak whats the tank made of
Old 05-15-2012, 09:41 AM   #6
It's water on the floor and can't see where it's coming from. Tank is made of plastic. Thanks
Warm water coming from cold faucets ygillard Plumbing 2 03-02-2012 02:24 PM
Hot water coming through cold water line mrdojo Plumbing 0 01-26-2012 04:19 PM
Concrete tank for solar water preheating? Badfish740 Building & Construction 5 03-09-2010 08:20 PM
Hot water tank leaking from valve pipe bookingohio Plumbing 11 05-07-2009 09:43 PM
Help with low pressure cold water upstairs lewissv Plumbing 5 01-26-2007 08:05 AM
