Leaking Center Hole - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-12-2011, 06:37 PM   #1
Leaking Center Hole
I've installed a 3 hole 4" faucet in my basement bathroom. When the faucet is turned on water leaks through the center hole, thoughts/solutions?
azimmerman11 is offline   Reply With Quote
Old 01-12-2011, 06:46 PM   #2
Sounds like the faucet may be defective. You might want to take it back and get a new one.
VIPlumber is offline   Reply With Quote
Old 01-12-2011, 07:26 PM   #3
First thing I would do is tighten the packing nut-there is probably a nut under the trim ring. The shaft of the stem should extend through the packing nut and there is a rubber or plastic washer under the packing nut which is suppossed to let the stem spin but make it watertight.
broox is offline   Reply With Quote
Old 01-13-2011, 07:27 PM   #4
Picky Plumber
Could be a cross threaded aerator or a bad solder joint in the faucet. take it back, get a new one
Plumber26 is offline   Reply With Quote
How to repair a hole in cast Iron pipe? bofusmosby Plumbing 26 11-13-2011 09:35 AM
Cutting out a hole on a stainless steel sink...pics Goldglv General DIY Discussions 14 02-28-2010 10:04 PM
freezer leaking into fridge - cannot locate drain hole pro_DIYer Appliances 5 12-31-2008 11:08 PM
leaking bathtub mikeynholly Plumbing 1 02-11-2007 01:50 PM
I hope I don't have to tear down the ceiling brds16 Carpentry 9 04-30-2005 10:16 AM
