Leaking Between The Meter And The House - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-12-2010, 04:43 PM   #1
Rewards Points: 87
Leaking between the meter and the house
It is found that there's a leak in the pipe between the meter and the house.
The pipe's probably been there for 25 years (as long as the house is built). How long does a copper pipe usually last?
Should I replace the whole thing (~$3k) or just do the leak detection and fix the leak (~$1k)? Thank you.
Stephen S. is offline   Reply With Quote
Old 01-12-2010, 05:12 PM   #2
Replace the whole line.
SULTINI is offline   Reply With Quote
Old 01-12-2010, 10:02 PM   #3
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
is it a fitting leaking or hole in pipe?
plummen is offline   Reply With Quote
Old 01-13-2010, 06:30 AM   #4
Well you can try to find the leak if you want to but any water lines I have seen are rolled K copper one continuous piece if shorter than 50 '.
If it's leaking where it ties into the curb stop valve then maybe it can be fixed but good luck finding a joint in the line.
Where is your meter in relationship to the house??
Copper leaks are like light bulbs once you have one leak another is soon to follow.
Once one light bulb burns out another is close behind.
Old 01-13-2010, 08:06 AM   #5
plummen's Avatar
thats why i was wondering if it was just a mechanical connection at stopbox or meter pit that was leaking,something simple like a bad flare or loose nut.
Old 01-13-2010, 09:10 AM   #6
First, you need to determine where the pipe is leaking. A bad connection could be easily fixed. If it is holes in the pipe, replace the whole line.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 01-13-2010, 02:10 PM   #7
Rewards Points: 87
Update: It is found that the buried house water service pipe is some kind of plastic pipe then switch to copper pipe as it enters the house (underground ? I don't see where it's connected/ converted ...) and the leak is somewhere along the plastic pipe so installing a new copper pipe is the way to go.
The plumber told me that there was a lawsuit against using this kind of plastic pipe but it's a while ago (anyone heard about this? I'd love to know the outcome)
1) It's a 1" pipe. If I were to install a sprinkler system in future along the main water service pipe, is it necessary to increase to 1.25" pipe? The front yard area is around 250 sqft.
2) Is there a hole digger for digging a pipe tunnel to put the copper pipe through? or do I need a trench digger to dig a trench from the meter to my foundation (90 feet)?
3) Rolled pipe or rigid pipe?
Thank you.
Old 01-13-2010, 04:31 PM   #8
ANSWERS
1. Not sure
2 Trench Digger
3 Roll 1" K Copper 100 feet.
Note : When you install the new line run the new copper from the meter all the way through the foundation to the copper in the house.
You should also put a sleeve in the foundation wall that the new line runs through. Be careful not to kink it.
Old 01-14-2010, 06:43 PM   #9
Rewards Points: 40
Another answer to your question 2 might be directional boreing.I don't know what the costs or availability of one of these machine in your area are.These machines are not a rental item and therefore not a DIY project.The advantage would be clean-up at each end only and not across the whole yard.
daveb1 is offline   Reply With Quote
Old 01-14-2010, 06:51 PM   #10
"Pipe Bursting": http://en.wikipedia.org/wiki/Pipe_bursting
Ishmael is offline   Reply With Quote
