Leaking Bathtub - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-31-2005, 02:31 PM   #1
Leaking Bathtub
Last night I was startled by a dripping noise in my downstairs hallway. From on of my can lights there was water dripping. Directly above the dripping is my kids bathtub. One kid had just finished taking a bath and the tub was empty other than my other taking a shower. Of course I have no access panel to the pipes, although there is a close right behind the bathtub pipes.
The tub doesn't appear to have any cracks in it. I can't imagine that the water is going through any of the grout lines. What are the likely problems for this? I plan on looking through the can light hole to see if I see the plumming but I'm assuming that I'll need to cut a hole in the closet for access.
Thanks for any help,
Dave
woodinville guy is offline   Reply With Quote
Old 08-31-2005, 11:29 PM   #2
Contractor
KenTheHandyMan's Avatar
Rewards Points: 150
First, I would try to tighten the drain (clockwise). Some of these drains can become loose and water will leak out.
I wouldn't enlarge the can light hole yet because even if you can see something there (by all means look) it will likely be fixed by the drain. So if the drain tightening doesn't work, I'd open the wall up first.
Regards,
Ken Walker
KenTheHandyMan is offline   Reply With Quote
Old 08-31-2005, 11:41 PM   #3
renovations
Did your kid inadvertently overfill the tub? Sometimes the washer on the overflow is not seated correctly and no-one will notice for perhaps years until it is needed. If you think that might be it, just unscrew the trim piece and have a look. There should be a large tapered rubber washer right behind the bar that holds the trim on. Loosen the bar (two screws) reseat the washer and tighten the bar, then put the trim back. Just a possibility, but a whole lot better than repairing drywall. Rich.
Bonus is offline   Reply With Quote
Old 09-01-2005, 02:32 PM   #4
After cutting the hole in the closet last night I figured out the water is coming through the grout for the tile.
Everything else looks good. No mold that I can see. Should I spray a bleach solution to be safe?
This weekend I'll be removing the old grout and putting in fresh new grout.
Thanks for the help!
Dave
Leaking Bathtub rstout69 Plumbing 16 03-31-2009 02:59 PM
Leaking bathroom floor patatura Flooring 6 12-06-2008 07:30 PM
water leaking from pressure balance spool lauralyn1 Plumbing 16 08-13-2007 05:50 PM
leaking bathtub mikeynholly Plumbing 1 02-11-2007 02:50 PM
Help with ID'ing bathtub sound... DIY-Gal Plumbing 12 02-10-2007 06:45 AM
