Old 02-11-2007, 01:12 PM   #1
leaking bathtub
I am not sure where to start. My tub is leaking (hence the title ). I cut a hole in the ceiling to see the area better and I have the advantage that a closet shares a wall with the shower where the faucets are and a hole has been cut so I can see the pipes. It looks like it is coming from the cold faucet (there is a wet spot in the drywall at that point) The drain is leaking, and it looks like it is leaking behind the spout.
I am up for lots of ideas or suggestions, but my main concern is how do I fix or reseal the drain, as it looks like it is coming from the pipes on the under side.
Any thoughts anyone?
Sorry for the lengthy message
Mikey
mikeynholly is offline   Reply With Quote
Old 02-11-2007, 02:50 PM   #2
leaking bathtub
Lets start with the drain. You need to be sure "where" the water is coming from. Could be a "slip-joint nut", the pipe itself, or the flange inside the tub may need to be resealed with plumbers putty. Find the spot it's leaking and we will work from there.
The cold water leak could be a bad solder joint (if piping is copper), or a bad cement joint if it's plastic pipe. Again, find the spot it's leaking at.
The spout. Look under the spout where it contacts the wall. If there is a slot, there is an allen screw that holds the spout onto the pipe. There are also "O" ring(s) that form the seal between the spout and pipe. Loosen or remove the screw and, with a twisting motion, pull the spout off and inspect the ring(s). Replace if necessary. If no slot, it screws onto the supply pipe. Turn the spout counter-clockwise and unscrew it. Re-dope with either teflon tape or joint compound. Screw it back on until the spout faces down and then recaulk around the base. NOTE: It MAY be that the leak is coming from a bad seal around the base of the spout (especially if you have a shower also). Check this area first. Good luck and let us know what you find.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
More On This Topic
Hi! This is John on behalf of expertvillage.com. In this video clip, I will show you how to check for engine coolant leaks. As you take a look at your engine coolant reservoir, you will notice that there are several hoses coming and going from your... Read More »
Hey everybody Don Golden for Expert Village and we are having fun with copper today, copper piping. We just put this joint together and I felt it was my duty to show you a new technology that really makes this even easier and it is pretty easy as it is... Read More »
Ok, so on the new oven on the new stove, the gas inlet is here. So that's where the gas is going to go in and then it goes into a regulator and then goes to the valves and to the burners. So we're going to need the fitting which will go into this, this... Read More »
Hi, this is Robert Stewart, with hill13.com. Now, the tank being essential, you need to know how to do a couple of things with it. The first is replacing the o-ring. The second, though a little trickier, is the burst valve. Now, if you're, if this is... Read More »
Roof leaks may not be immediately apparent, which is one of their inherent problems. As a roof leaks, there is the danger that mold and mildew will accumulate. In addition, actual structural damage is also a possibility. That's why it is so important to... Read More »
Leaking Bathtub rstout69 Plumbing 16 03-31-2009 02:59 PM
Leaking bathroom floor patatura Flooring 6 12-06-2008 07:30 PM
water leaking from pressure balance spool lauralyn1 Plumbing 16 08-13-2007 05:50 PM
Help with ID'ing bathtub sound... DIY-Gal Plumbing 12 02-10-2007 06:45 AM
Leaking Bathtub woodinville guy Plumbing 3 09-01-2005 02:32 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
