Leaking Bathtub - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-29-2007, 04:02 PM   #16
How did you go about fixing the problem? I've never done any job like this so you can break it down as simple as you see fit! Also, Did you have to dry up the area under the tub? Thanks.
Luke_S_G is offline   Reply With Quote
Old 03-31-2009, 01:59 PM   #17
Re: rstout69....8/06,,help Ron the plumber
rstout69 posted a bathtub leak problem, in aug. '08 and that is exactly what mine is doing.
It leaks in the basement below the shower. You can see that the water has traveled. So we tore off the bottom of the wall in the bedroom on the other side of the tub/shower. UGH all moldy insulation,etc. We cleared it all up and took a look see while we turned on the shower. Like rstout69, nothing happened until someone stood inthe shower. But your solution,
to make sure that sure you caulk good where (in our case ceramic tile wall) wall meets tub lip. We have done this several times in the last 2 yrs...YOW...each time I would fill the tub with water while I caulked and it set. Only to have the problem return. It is NOT the drain, or the over flow, or any gaskets by the spout fixtures. We can see clearly thru the wall now that the water IS coming from the lip when someone is in the shower. How else can we caulk good between the ceramic tiles and the lip.
Immediate help needed
thank you
bobfixit is offline   Reply With Quote
Leaking bathroom floor patatura Flooring 6 12-06-2008 06:30 PM
water leaking from pressure balance spool lauralyn1 Plumbing 16 08-13-2007 04:50 PM
leaking bathtub mikeynholly Plumbing 1 02-11-2007 01:50 PM
Help with ID'ing bathtub sound... DIY-Gal Plumbing 12 02-10-2007 05:45 AM
Leaking Bathtub woodinville guy Plumbing 3 09-01-2005 01:32 PM
