#1 |
Leaking bathroom sink drain - how to fix?
Hi guys,
The drain in my bathroom sink is leaking. I've attached a few pictures, but it looks like the drain is a hack job (I didn't do it!). The drain pipe is attached to the trap by some plastic flexible tube secured with a hose clamp. When I run the sink, water starts to seep out around the hose clamp and leak onto the floor. I tried tightening the clamp, but to no avail. The rest of the drain seems to function properly - do I just need to get another one of these flexible tubes? I also have another question - in the second picture, you can see a close up of the trap. only one side has a threaded connector. The other end seems to be attached directly to the drain pipe? If I needed to remove or replace this trap how would I get it off, would I have to cut the pipe to get it off? Thanks! |
#2 |
You need what's called an 1-1/4 tube extention. It male on one end and female slip on the other. Your going to just have to cut it to length.
http://images.search.yahoo.com/image...mb=cpCLpHoH11V Looks like that blue pipe under the sink. Last edited by joecaption; 02-22-2012 at 12:23 AM. |
| The Following 5 Users Say Thank You to joecaption For This Useful Post: | ben's plumbing (02-22-2012), oh'mike (02-22-2012), plummen (02-22-2012), TheEplumber (02-22-2012), thinksincode (02-22-2012) |
#3 |
Leaking bathroom sink drain - how to fix? |
#4 |
it looks like to me you have a copper drain soldered on to the trap to replace trap you will need to cut copper pipe then a fernco with a sink adaptor then use normal tube trap
make sure you get the correct fernco plastic to copper http://www.homedepot.com/h_d1/N-5yc1...&storeId=10051
be careful my advice only comes from general knowledge i know about the 4 rules it takes to plumb and they are 1 poop needs to flow down hill. 2 hot on left cold on right 3 i get a pay check on Mondays 4 do not chew finger nails at or after work. |
#5 |
no it has a nut and tapered Ferrell that when you tighten it done it seals just like the nut on trap but that one usually has a rubber seal under nut make sure tube extension is 1 1/2 with a 1 1/4 to 1 1/2 ferrell just tell the box store or hardware what you are doing and they will show you the right part and how it works
#6 |
No furnco needed, no clamp needed. There's a tapered plastic washer and a plastic nut going to be at the top and you should be able to reuse what you have at the bottom if there's another taper washer under that silver nut, if it's not there then just pick one up while in the store, there cheap.
Did you look at the picture I sent you. That's what it was suppost to look like. |
| The Following 2 Users Say Thank You to joecaption For This Useful Post: | ben's plumbing (02-22-2012), thinksincode (02-22-2012) |
#7 | |
Leaking bathroom sink drain - how to fix?Quote:
#8 |
yes my post was if you wanted to replace trap sorry if i confused you
| The Following User Says Thank You to jaydevries For This Useful Post: | thinksincode (02-22-2012) |
#9 |
#10 |
Thanks for the help, guys! I picked up a flexible tailpiece extension at Home Depot and put it on. I got the flex one because there is a slight misalignment between the trap and the drain. Here's an "after" photo:
![]() One thing you might notice is that the extension is a little crooked where it attaches to the drain. I tried several times, but as I tightened the nut it went a little crooked again. I didn't want to force it and put lateral force on the other pipes. Should this be ok? |
#11 |
looks good it will work if it does not leak
also being in a bath you might never have this problem but i have seen this a few times in a kitchen so i will let you know about these flex tail pieces if in the far future you start to smell something bad in bath it might be the tail piece stuff gets caught in ridges and starts to stink some times
#12 | |
Master Plumber
Experience is Knowing what to do next, Skill is knowing how to do it To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
| Tags |
drain, plumbing, sink ![]() |
| Display Modes | |
| sink drain exterior wall | iskyfly | Plumbing | 11 | 02-04-2012 07:38 PM |
| Bathroom sink drain repair help | mainstreeet | Plumbing | 30 | 02-04-2012 03:20 PM |
| new sink drain assembly is leaking | suziesmith | Plumbing | 5 | 03-03-2011 04:34 PM |
| Leaking cast iron drain pipes + roots in 4" main line | aminus21 | Plumbing | 5 | 09-25-2010 11:21 AM |
| Maximum distance of sink from drain? | DIYHomeTheater | Plumbing | 0 | 06-14-2010 08:42 PM |
