As you can see in the picture I've got a small bead of water forming in the crack where that collar meets the main body of the valve.
It forms whether I have the valve open or closed. It's not much, maybe a couple drops a day, but as you can see it's already taking its toll.
Did I just get a bad valve, or is it more likely that I overheated it when soldering? Whatever the case, there's a leak and it needs to be stopped!
Is there any solution beside taking the whole thing off and replacing it? You know, like some sort of magic plumbing trick?
Any help/suggestions/comments appreciated. Thanks
