Leaking Ball Valve In A Gas Line - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-13-2012, 09:16 AM   #16
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Originally Posted by George6488 View Post
Gas company has a shut-off somewhere in the line. How could they shut-off your supply if you didn't pay the bill?
I am not a plumber......but I would install the new valve without shutting off the gas. Just ventilate the room real well and make sure all sources of ignition are turned off such as a water heater pilot.
Work fast!
Journeyman Plumber
Old 07-13-2012, 09:41 AM   #17
Rewards Points: 1,216
I agree with Alan, do not try to change this valve on the fly it's not water or air it's BOOM gas. How many people have try-ed to install valves on the fly and something goes wrong and it's open with no way to shut it off and panic sets in? I have.
COLDIRON is offline   Reply With Quote
Old 07-13-2012, 09:58 AM   #18
Rewards Points: 352
that old gas shut off is no longer code for the very reason you are having a problem with it. change it to a new valve. If you want to discount the knowledge of the people who do this type of work every day then do it your way.
plumberinlaw is offline   Reply With Quote
The Following 2 Users Say Thank You to plumberinlaw For This Useful Post:
COLDIRON (07-14-2012), TheEplumber (07-13-2012)
Tags
ball valve , gas , leak
ball valve leaking bwall Plumbing 10 12-31-2012 07:25 PM
Leaking shut off valve, am I that inept??? ChrisDIY Plumbing 12 07-28-2012 07:52 PM
Leaking cast iron drain pipes + roots in 4" main line aminus21 Plumbing 5 09-25-2010 10:21 AM
New ball valve leaking half open? sz8 Plumbing 5 01-05-2007 10:46 PM
leaking 1 1/4" Brass Ball Valve creemore Plumbing 2 03-11-2005 08:23 PM
