Leaking Ball Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-24-2011, 08:20 AM   #1
leaking ball valve
I installed brand new 1/2inch; sweated ball valves horizontally with the handles on the bottom and 2 of them are leaking slightly from the handle mount. Is there something I can do to stop the leak short of sweating new valves?
sparkytom is offline   Reply With Quote
Old 11-24-2011, 08:27 AM   #2
Rewards Points: 582
is there a packing nut behind the handle..if so remove handle and snug up nut gently though....if not may have over heated valve when soldering.....pics would help...ben
The Following User Says Thank You to ben's plumbing For This Useful Post:
sparkytom (11-24-2011)
Old 11-24-2011, 08:58 AM   #3
leaking ball valve
overheated when soldering? really? it's just dripping ever so slightly. tightening the nut worked on one but not the other. Can I change or add packing? If so, what should I use? I do have new, uninstalled valves (prochannel brand)
Old 11-24-2011, 09:17 AM   #4
Rewards Points: 582
if they have packing nuts and i assume they do since one worked. tighten the other up tighter worse case will need to replace anyway...I think packing is small white ring......and yes you can overheat when soldering and cause damage.....maybe take new valve apart and see what there and see if you can repair the one leaking.......your choice...
Leaking Ball Valve tggfixup Plumbing 4 10-24-2011 09:56 PM
Leaking Pressure Relief Valve of Boiler rob07030 Plumbing 2 11-02-2010 07:11 AM
New ball valve leaking half open? sz8 Plumbing 5 01-05-2007 10:46 PM
leaking 1 1/4" Brass Ball Valve creemore Plumbing 2 03-11-2005 08:23 PM
