Leaking Ball Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-24-2011, 08:26 AM   #1
Rewards Points: 16
Leaking Ball Valve
I have a ball valve on the cold water line which controls water flow to an exterior building. I rely on the valve to totally stop the water flow to that exterior building during the winter months. The valve is used twice a year, once in the fall to turn the water off, and again in the spring to turn it back on. This year, I discovered that even when the valve is in a fully closed position, I'm getting a slow drip from the closed valve. Is there a way to repair this, or should I be looking at replacing the entire valve.
tggfixup is offline   Reply With Quote
Old 10-24-2011, 08:52 AM   #2
DIY staff
Rewards Points: 7,174
Just change the valve---they rarely fail so the new one should take care of the problem.
Old 10-24-2011, 09:01 AM   #3
Lightfoot's Avatar
Rewards Points: 272
Agreed
If it's not brass, i'd look at putting a brass one in-i've not had one fail yet.
Lightfoot is offline   Reply With Quote
Old 10-24-2011, 06:34 PM   #4
Rewards Points: 582
some older ball valves had a packing nut where handle meets body of valve this could be tightened up???????
Old 10-24-2011, 10:56 PM   #5
I agree with Ben. An 1/8th of a turn on the packing nut is a lot quicker, easier and cheaper than replacing the whole valve!
Ishmael is offline   Reply With Quote
Leaking Relief Valve Tobinator HVAC 1 01-16-2011 08:37 AM
leaking rad valve Grainoftruth Plumbing 2 12-17-2010 01:06 PM
New ball valve leaking half open? sz8 Plumbing 5 01-05-2007 11:46 PM
leaking 1 1/4" Brass Ball Valve creemore Plumbing 2 03-11-2005 09:23 PM
