Leaking Around Old Drain Pipe In Basement - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-15-2011, 06:18 PM   #1
spg
Leaking around old drain pipe in basement
My house was built in the early 70s. I just noticed water in the basement for the first time (after owning the house for a year), and traced it back to around this old drain pipe:
After looking at this, I'm pretty surprised that I didn't have water down here sooner. Feeling around, everything is totally dry above and around this pipe, and it seems to be the only place in the basement where water is coming in.
So I'm going to try to fix this. Is it just a matter of chipping out some of the old material around the outside of the pipe and then filling it with hydraulic cement? Any tips or advice for me on this one? I was planning on doing something similar to this video:
http://www.thisoldhouse.com/toh/vide...631555,00.html
Thanks in advance for any help/advice!
spg is offline   Reply With Quote
Old 08-16-2011, 12:27 PM   #2
spg
Anyone?
Possible to join PVC drain pipe to old iron pipe? darsunt Plumbing 7 03-01-2014 02:53 PM
Adding a basement floor drain for A/C Condensor SuzieSawzall Plumbing 9 03-28-2011 08:51 AM
Lead Drain Pipe Project Turbo98 Plumbing 33 01-30-2011 12:27 PM
AC Coil drain pipe questions fritzycat1 HVAC 14 11-12-2010 04:51 PM
Framing basement wall with drain pipe owais Remodeling 13 03-25-2009 10:48 AM
