Old 07-22-2008, 07:44 PM   #1
leakage on ceiling from bathroom above?
Our home is about six years old, when we first moved in we noticed that the ceiling in the living room had a water mark but thought it would not be a problem. Now almost four years later the water mark is much larger and the paint on the ceiling is pealing off...three days ago my son had his shower and the water started dripping. We were told not to use the shower for two days and then run the water from the tap to see if it would start leaking again. This was to see if the leak came from the shower or area under the bathtub. We have used the shower and let water flow from the bathtub but it did not leak.
We have been trying to open up the front cover of the bathtub by removing the silicon around the tub, grouch on the tile and panels from the drywall but the front cover will not move. Can anyone out there give us some advice?
Thank you for your time.
milly tseng is offline   Reply With Quote
Old 07-22-2008, 10:37 PM   #2
if your tub faucets dont have an access panel from the back,,,they should,,,see why?? MAKE one,,it will be used MORE than once!!!! You can be creative and decorative as your imagination allows. IF not possible,,at least cut drywall back there and repair as necessary. Dont forget to check risor pipe and shower head area,,water will run down if THEY are leaking, otherwise check faucets and drain pipes. Then when all else fails check grouting and wall leaks!!
4just1don is offline   Reply With Quote
Old 07-22-2008, 11:01 PM   #3
Moderator
Termite's Avatar
Bear in mind that grout alone is not waterproof, so even if the grout is in good shape the shower could have been constructed improperly. Water could be getting in anywhere, but I doubt that water permeating the grout would actually cause anything more than moisture problems in the wall and floor, but not actual visible leaks.
Check to make sure everything is caulked correctly. The next stop is to remove the ceiling beneath the shower since that drywall is already screwed up. See if the trap or drain is leaking. Then open the wall from the back side to try to find plumbing leaks in the mixing valve or other supply plumbing.
Old 07-24-2008, 10:49 PM   #4
Thank you both kindly for taking the time to read my post and giving me your advice. It is much appreciated. Now we know where to start!
Old 07-25-2008, 11:15 AM   #5
Licensed Master Plumber
mstplumber's Avatar
Before you start cutting drywall there are a few things you can do to try to narrow your choices.
First, make very sure that the water is not just running down the corner of the tub past the shower curtain while your son is taking a shower. Take a very close look at the wall and floor corners at both ends of the tub immediately after he is finished. Pay special attention to the end the shower head is on. I have seen many "leaks" that wound up being caused by water running over the edge of the tub. Enough people have this problem that you can but special little dams that stick in the corner on the tub to block the water.
If you are sure this isn't the problem the next step is to determine whether the leak is from the valve or from the drain. Since it doesn't leak all the time, it's not from the hot or cold inlet connections. These are under constant pressure and would leak continuously if they were the problem.
The easiest thing to check first is the drain side. You don't want to run the faucet because that will screw up this test. Fill a bucket up from another bathroom and use this to fill the tub. I know that's a pain in the neck but it's necessary. Once the tub is full let it sit for 30 minutes or so and see if the leak shows up. If so, it is from the tub drain. Drain the water and fix the drain. It probably just needs to be removed and re puttied. Clear silicone, though harder to clean up, works great instead of putty.
If no leak shows up while the tub is full go ahead and drain the tub, again checking for leaks. If you see a leak now the problem is in the drain piping. You will need to cut drywall to find and repair this. Start at the wet spot.
If no leak shows up from the first test, that leaves the tub spout piping and the shower head riser and connection. The two most likely places to check for a leak are the shower riser and connection and the tub spout piping and connection. The first thing to do is to pull the escutcheon (trim ring) at the shower head and see if you can see the connection inside the wall. You may have to open the hole a little, just enough so you can see but it will still be covered by the escutcheon. Now run the shower head while looking at the connection with a flashlight. If you can't see it very good, wrap some toilet paper around the end of a screwdriver and hold it under the connection for a minute. Check and see if the paper is wet. If so, or if you can see a leak, you've found the problem. Take the shower head off, stick the handle of your pliers in the end of the bent pipe coming out of the wall and remove it. Put some new teflon tape on the threads, screw it back in and check for leaks.
If you don't find a leak here check the tub spout. If you have the kind of tub spout with a diverter you have to pull to make the water go to the shower head it could be leaking where it connects to the piping and water could be running back into the wall. This is kind of hard to see but some brands have a small opening on the bottom side of the spout to tighten the spout clamp. You can use the toilet paper trick here too. If there is no opening you can try to unscrew the spout and see if the piping behind it is wet. If none of this works you may need to cut drywall behind the tub to really check it out (if you can get to it).
If you can find the source of the leak this way you may be able to fix it yourself and save some money. Even if you don't feel comfortable doing this, you will at least be able to let the plumber know what you've done and minimize the cost of the repair.
Mstplumber
Check out my goofy video for my new
mstplumber is offline   Reply With Quote
Old 03-09-2009, 01:23 PM   #6
I decided to resurrect this thread because I have exactly the same situation.
However, I have narrowed down the leak quite a bit now and am looking for advice on how to actually fix it.
For a long time I believed the leak was at the place where the shower neck meets the shower riser pipe elbow inside the wall. However I've replaced the neck with a new one, used a lot of teflon tape and nothing changed. Drip, drip, drip.
The drip comes when either the shower is running or there is water in the riser pipe (the shower/faucet handle is set on shower). So, my only remaining guess is that the leak is where the elbow connects with the riser pipe, because it is only when there is water in the column that the dripping continues. Is there another explanation?
And, if so, what do I need to do? Unfortunately I don't even have drywall on the wall that covers the piping - I believe it's plywood. And, I believe the problem to be more than just a leaky valve or washer because I know that the previous owners had this leak, since it was clear once the leak started again that the ceiling had been patched in exactly the same place before.
Any advice?
Thanks!
genEus is offline   Reply With Quote
Old 03-09-2009, 02:55 PM   #7
Cut out backside wall,,,you need an access panel back there anyway!!
Old 03-09-2009, 04:56 PM   #8
oops. see next.
Old 03-09-2009, 04:56 PM   #9
Can't. I don't know what is inside there but there's not just a wall, it's a huge space. Maybe this ascii art will help. S is where the shower is. XXXXX is the wall where I don't know what's inside. So you can see I don't have access to behind the shower riser pipe.
Code:
              | <- bedroom door
     S| XXXXX |
     | <- bathroom door
Old 03-09-2009, 07:46 PM   #10
Man of many hats
wrangler's Avatar
Not sure if this will help, but often with this type of leak I have found it to be where the riser to the shower head LEAVES the valve, meaning, where the copper pipe heading upward connects to the shower outlet of the valve. If this IS your problem, you MAY be able to re-solder it after taking off the escutcheon plate (cover of the valve). If nothing else, you can take off the plate, take a flashlight and determine if it is leaking there or from above as you originally suspected. If above, can you cut the drywall /plywood(if drywall/plywood there) repair the leak and then repair the drywall? Also, if I understand your diagram correctly, is there a large dead space behind the shower, between the bath and bedroom door? If so, you may be able to attack it from there and also add a small linen closet?
Let us know or post some pics if able.
Brett
Man of many hats
wrangler is offline   Reply With Quote
Old 03-09-2009, 08:53 PM   #11
Chimney spae?furnace duct space? plumbing chase space? If it were me I would pick a spot that if it worked out,either I would end up with a linen closet or another bedroom closet. BUT,I would open enough to see whats inside!!,,,even if you end up with a shadow box shelves for parking knick knacks with a 'false' back,removalble so you HAVE access when needed!!
Tags
bathtub, front cover, leaking, shower, silicon
ceiling paint in bathroom gorilla325 Painting 15 09-10-2012 07:07 PM
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 09:26 AM
Drop ceiling in basement bathroom handyflyer Remodeling 23 05-26-2009 10:12 PM
Soffit Running Thru Bathroom / Dropped Ceiling xlr8tn Building & Construction 3 01-23-2008 07:37 PM
excessive moisture on bathroom ceiling Den69RS96 General Discussion 8 01-14-2008 09:37 AM
