Leak From Water Heater??? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-28-2012, 08:31 PM   #1
leak from water heater???
i cant see water coming from the water heater in my garage, but every day there is a bunch of water leaking out of my garage. i assume its from the water heater becasue thats where the water spot starts at it looks. the water meater keeps going around so water is coming from somewhere! everything is turned off in the home. it sounds through the wall water is on but i had not turned anything on. what do you reccommend
hmpadilla is offline   Reply With Quote
Old 02-28-2012, 09:02 PM   #2
Rewards Points: 13,300
Finding the leak is the first thing to do.
Clean up the floor and see where it starts.
Is this gas, electric.
Is it sitting directly on the concrete floor?
Old 02-29-2012, 09:08 AM   #3
Rewards Points: 1,452
Turn off the cold water inlet shutoff above the water heater. Does the meter stop spinning?
(This is not foolproof; sometimes that shutoff doesn't close completely due to sediment particularly if the shutoff is not exercised every once in awhile.)
The Following User Says Thank You to AllanJ For This Useful Post:
ben's plumbing (02-29-2012)
Old 02-29-2012, 08:45 PM   #4
how
Rewards Points: 1,104
If your HWT has a 3/4" drain line dropping down towards the floor from the P&T valve, put a small container under that 3/4" outlet to see if that is your water source.
how is offline   Reply With Quote
no water at sink after water heater removal rebelbull Plumbing 2 07-19-2011 01:37 AM
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 09:17 PM
Multiple hot water heater issues a-6intruder Plumbing 8 01-16-2009 06:58 PM
Hot water heater leak? chrisintroy Plumbing 3 02-27-2006 10:13 AM
Hot water heater leak? ddasher8 Plumbing 1 07-03-2005 06:00 AM
