Leak Under Tub At Joint To Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-10-2011, 03:21 PM   #1
Old Hand
Leak under tub at joint to drain
I discovered a leak under the tub where the horizontal pipe is attached with the nut to the joint for the drain. Note the "garbage that is stuck to the pipe where the nut/ferrule is joined. When I tried to tighten the nut, the leak got worse. Since there is no clearance/area to move the pipe, it appears I may have to take out the drain pipe from the tub and then reinstall this with a union (if there is room). Any other suggestions would be appreciated. (2 photos attached).
iliketowork is offline   Reply With Quote
Old 12-10-2011, 06:17 PM   #2
Pics are MIA.
VIPlumber is offline   Reply With Quote
The Following User Says Thank You to VIPlumber For This Useful Post:
plummen (12-10-2011)
Old 12-10-2011, 06:50 PM   #3
Old Hand
Here is photo: Updated information
I noticed that the nut is cracked on the photo; went back to look and sure enough, it is split. I believe I will have to take out entire assembly from tub to joint connection; not sure how I will reinstall with no clearance. Photo now included (sorry, did not see I had to resize). Thanks,
Old 12-10-2011, 06:56 PM   #4
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
remove strainer from bottem of tub ,youll need a tool called a dumbell and a big cresent wrench to to turn it from top side of tub.
any hardware store should sell one.
you might be better off to just buy a new waste/overflow assembly while youre at it since your bottem gasket apears to be gone ,somebody just packed it with plumbers putty.
buy a little bucket of plumbers putty for top side reinstall,hardware guy can explain
plummen is offline   Reply With Quote
The Following 2 Users Say Thank You to plummen For This Useful Post:
iliketowork (12-11-2011), oh'mike (12-10-2011)
Old 12-10-2011, 07:15 PM   #5
DIY staff
Rewards Points: 7,174
Plummen is offering a good solution---you will also need a 'trap adapter' for the pipe if you decide to add a new tub drain set---
Tags
leak in abs , tub drain leak
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 12:20 PM
Shower Drain Leak dougp23 Plumbing 1 10-17-2011 09:30 PM
No Caulk Shower Drain - Leak 9lostboy5 Plumbing 12 03-26-2010 10:00 AM
Washer on/off drain leak opper3 Plumbing 1 03-02-2009 05:06 AM
Leak at flange and drain pipe tallycat77 Plumbing 1 07-26-2005 08:32 PM
