Old 12-01-2009, 11:47 AM   #1
leak under kitchen sink
HI everyone,
Today I noticed water leaking out of the cabinet under the kitchen sink. So I looked in that cabinet and noticed a significant leak. The leak is due to two pipes not even being connected, although that wasn't obvious until I touched the pipes. This is strange since I didn't disconnect the pipes and I can't imagine anyone else did either. See the pictures.
Assuming the pipes were originally connected, I can't tell how. Perhaps they were glued or perhaps some connecting part fell off. Does anyone know if this is a quick fix, and what to do about it?
Thanks.
JP79ST is offline   Reply With Quote
Old 12-01-2009, 12:01 PM   #2
Xtreme DIY'r
It's a compression fitting
Unscrew it, push it back up, then screw it down tight
Most likely someone just hit it...maybe a few times over the years & it eventually slipped off
Old 12-04-2009, 06:50 PM   #3
That worked...Thanks
Old 12-04-2009, 08:54 PM   #4
The waste arm shown in the picture is of a lightweight plastic and these while cheap are prone to lossening over time. Your draining hot then cold then hot again........over time the expansion and contraction loosen the fittings. They are supposed be hand tight ONLY. You'll just have to keep tabs on them. One thing I like to do under sink and basin cabinets is to put down those inexpensive 12 x 12 self stick tiles. I lay them down and cut some in half to seal the sides (up 6"). That way any leaks or spills from all the under sink chemicals most of us have won't rot the bottom of the cabinet. Have fun.
LeakyMike is offline   Reply With Quote
Smell Under Kitchen Sink mamaerin General Discussion 4 09-23-2009 12:01 PM
Leak Under Kitchen Sink wallix Plumbing 1 08-05-2009 02:49 PM
Anybody install or own a CORNER kitchen sink? Also RTA cabs... matermark Kitchen & Bath Remodeling 2 01-24-2009 06:41 PM
Cast iron self-rimming kitchen sink & granite tile ILjXYZ Kitchen & Bath Remodeling 1 01-03-2009 06:53 PM
Kitchen sink recommendations? pweller Plumbing 4 07-08-2008 09:43 AM
