#1 |
leak in toilet tank and water suply
I found a leak where my water supply feeds my tank.
I shut off the water, cleared the tank, and installed a new water supply. But, the leak is still there. It appears to be at the threaded plastic "valve" where the supply attaches. it is a light drip... maybe one every 30-60sec can i just add some GOOP/silicone to strengthen the seal? should i be looking at a new tank? thanks Kevin |
#2 |
Owner
You shouldn't need a new tank. Simply replace the fill valve with a new Fluidmaster. They're 8 or 10 bucks and takes about 5 minutes.
Brad Penske, Operations Manager - Coeur d'Alene, ID LateralCONCEPTS,LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting (208) 818-8241 To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#3 |
Guessing that the male threaded adapter that the water supply line attaches to is cracked. As stated, replace the fill-valve with a Fluidmaster unit. Under $10 at hardware and Home Centers.
If you have never made a mistake, you haven't done much. |
| Display Modes | |
| Low hot water pressure | crebive | Plumbing | 38 | 02-26-2013 01:26 AM |
| shower leak..hot water tank leak...HELP!!! | Drie | Plumbing | 6 | 06-30-2010 03:12 PM |
| Toilet | jpark | Plumbing | 18 | 01-05-2009 08:12 AM |
| (Water Heater MYSTERY) Hot water out from dead tank with cold water in it? | Inayity | Plumbing | 6 | 07-14-2008 09:36 PM |
| Upstairs toilet pipe noise | bliss | Plumbing | 8 | 01-10-2008 08:55 AM |
