Leak That Stopped Leaking? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-28-2011, 02:13 PM   #1
Hey folks,
I've owned my house for 5 years. Never had a problem with pipes leaking. Today I went into my basement and it was all wet right below one of our 1/2 baths. The beams were wet right around the pipe below the sink. Nothing was dripping though. I'm in the basement often and so I'm pretty sure this is a new problem.
So, I had my wife run the faucet and flush the toilet multiple times. But no water came out/leaked.
Can you get a momentary temporary leak? Why would this happen? Not sure if this could be related, but this is in Massachusetts and it's been a brutal winter.
Do I rush to call the plumber or best wait till I can at least see the leak?
nullqwerty is offline   Reply With Quote
Old 01-28-2011, 02:28 PM   #2
Experienced
Jackofall1's Avatar
Depends, are the beams you refer to at an outside wall?
Is there an outside tap tee'd to this piping, possibly frozen?
Old 01-28-2011, 02:30 PM   #3
It's near an outside wall but at least 3 feet away. Nothing near an outside tap. Just surprised that it would start leaking and then stop. Has me puzzled.
Old 01-28-2011, 02:32 PM   #4
Experienced
Jackofall1's Avatar
How's the floor around the toilet?
Is it possible the toilet connection to the flange is leaking or has leaked?
Old 01-28-2011, 03:00 PM   #5
If the engine in your car makes a funny noise does it go away when you turn up the radio? It's doubtful that a leak fixed itself. It must have found a secret place to soak in.
Dwoodsmith is offline   Reply With Quote
Old 01-28-2011, 03:12 PM   #6
The bathroom is totally dry. Checked the sink, the floor, toilet,etc.
Think I figured it out. I think it's the roof line above the bathroom that's leaking straight down into the basement.
Old 01-28-2011, 03:32 PM   #7
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,384
Ayuh,.... Water flows downhill,...
Keep lookin' higher til there's no more water, 'n you Just passed by the Leak...
Old 01-28-2011, 07:25 PM   #8
Rewards Points: 530
Let me throw something out here.
Fill the sink, go to the basement so you observe and have your wife pull the drain to the sink. Watch the area for a minute or two to see if any water drips.
I'm thinking maybe a partial blockage that causes a leak only when a rush of water is going through the waste pipe.
Maybe go into the attic to check for signs of water entering if nothing is found while draining the full sink.
Also check that the water is not running along one of the floor joists before it gathers and drips.
The drain is close enough to the vent for the vent to be effective, right?
Might be surprised how soap, shaving lather and hair can build up in the pipes at the turns where it goes in the wall.
My house is old, and the drain for the sink takes a 90 degree just inside the wall back toward the main. Kitchen is the same way, and I have had to rod it out a few times over the years.
Old 01-28-2011, 07:39 PM   #9
Rewards Points: 163
Check the boot around the vent stack on the roof. Sometimes they pull away from the vent stack just far enough to let some water run down the vent pipe to the basement. Caulk around the boot or replace it if necessary.
kb3ca is offline   Reply With Quote
leak leak leak dongdong1 Building & Construction 4 01-11-2011 09:21 PM
Bathtub Drain Leak Help! jgcable Plumbing 54 12-19-2010 10:40 PM
Shower leak (what else) Old home, new owner... Rubbertree Plumbing 8 09-25-2009 01:26 PM
New acrylic bath tub install weird leak Panch Plumbing 5 08-23-2009 05:23 PM
Tile+Asphalt Roll Roof leaking - Opinion on what to do brookbphx Roofing/Siding 5 01-06-2009 06:51 AM
