Old 12-28-2011, 06:04 PM   #1
In a little over my head
leak in PVC DWV fixed!
I've asked plenty of questions around here. My turn with an answer, and a neat trick. I can't take credit for it; I found it on the internet.
To make a long story short, I had a tiny leak in the DWV for my new bathroom. In a bad place, too. I really didn't want to cut it out. I sealed up all the openings but one (lav sink drain) and sealed my shop vac in the pipe. My wife sat at the vacuum switch while I went under the house. When I touched the leak with the purple primer dauber, I could hear it suck primer in. Pffffffffffffft. Dab with the glue dauber. Pfft and FIXED!
Neat trick.
ratherbefishing is offline   Reply With Quote
Old 12-28-2011, 06:38 PM   #2
Super Moderator
That is one to remember!! Thank you---
Old 12-29-2011, 12:13 AM   #3
Master Plumber
Javiles's Avatar
keep an eye on it chances are that it will leak again.PVC (glue) is not a glue it’s a solvent when you join the two connections you have to give them at least a quarter turn the solvent fuses the two sections together.
Experience is Knowing what to do next, Skill is knowing how to do it
Javiles is offline   Reply With Quote
Old 12-29-2011, 12:54 AM   #4
Super Moderator
I never heard of 'have to give it a quarter turn' --Why?
Old 12-29-2011, 12:56 AM   #5
Persona Non Grata
VIPlumber's Avatar
Mike,
Friction so that the bond made by the primer & glue melting the pipe creates a stronger bond.
VIPlumber is offline   Reply With Quote
Old 12-29-2011, 12:57 AM   #6
Super Moderator
Thanks---
Fixed water leak now low pressure whitecrow Plumbing 15 08-13-2011 12:36 PM
Roof leak nightmare..... it won't stop amandat37 Roofing 52 04-22-2011 01:47 PM
Apartment water leak - questions haris General Discussion 2 03-23-2011 08:26 PM
leak (hopefully fixed), some rotten wood novive Carpentry 10 12-13-2010 05:28 PM
Shower leak (what else) Old home, new owner... Rubbertree Plumbing 8 09-25-2009 02:26 PM
