Old 01-26-2009, 04:20 PM   #1
Leak from a PVC Drain Pipe
I have a PVC drain pipe from a tub that is leaking at the Y conection to the main drain pipe. It is in a very hard to reach spot (through an access panel) unless I tear out some ceiling underneath. My question is can I re-glue the joint without taking the pipes apart? Is there a way to "seal" the connection?
John
firemedic589 is offline   Reply With Quote
Old 01-26-2009, 07:20 PM   #2
you could try to primer and glue the area, not the best option , but it might work, make sure you no exactly where the leak is, clean the area well with primer, then dob more glue on, i would wait ten minutes then repeat with more glue(do not repeat the primer).
zosoplumber is offline   Reply With Quote
Old 01-26-2009, 07:28 PM   #3
Building and plumbing
USP45's Avatar
I concur. Leaks like that though are hard to fix like that. I always find a way to cut them out completely and replace.
USP45 is offline   Reply With Quote
Old 01-27-2009, 03:44 PM   #4
I agree, adding glue is a shot in the dark. Replacement is best. If replacement is not an option that crazy loudmouth guy on tv sells some kind of epoxy stuff that might be an option. Still a long shot though.
jporter5333 is offline   Reply With Quote
More On This Topic
This is Kevin with Expert Village we are going to one day bathroom remodel. We are going to brighten up this bathroom a little bit and make it look presentable. As you have already seen it's not in the greatest shape but there is a few things that we can... Read More »
This is Kevin with Expert Village we are going to one day bathroom remodel. Now if you notice Kevin has to stick the strip completely with his left hand so he can keep pressing firmly where no bubbles appear under the surface. Once you have it going and... Read More »
This is Kevin with Expert Village we are going to one day bathroom remodel. Of all the places the edge of the bathroom tub is the most important to get completely cleaned of debris. It is not a like you are waisting your money because your tub sealer... Read More »
How to Clean a Bathtub
How to Clean a Bathtub by Expert Village
This is Kevin with Expert Village we are going to one day bathroom remodel. The final part of the bathtub cleaning preparation once we remove the sealer strips that we already got down here would require rubbing alcohol to get the really fine layer of... Read More »
How to Install Carpet
How to Install Carpet by Expert Village
This is Kevin with Expert Village we are going to one day bathroom remodel. At the end of the process when we got the carpet in place there where existing nail strips all around the outside of the room and I simply went around and step on the carpet so... Read More »
Drain Pipe MrMrsSip Plumbing 2 11-21-2008 06:46 PM
Bubbling in toilet rballard Plumbing 11 08-30-2008 08:15 PM
sewer backup and stench jayhill Plumbing 12 08-14-2008 12:06 AM
New bathroom drain pipe leaks PAK Plumbing 2 07-29-2008 10:36 AM
Leak at flange and drain pipe tallycat77 Plumbing 1 07-26-2005 09:32 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
