Old 12-11-2010, 02:02 AM   #1
Leak from pressure relief valve
i have a slow leak coming out of the pressure valve and was wondering if i have to change it or if there is another solution for the leak.
CHRIS650 is offline   Reply With Quote
Old 12-11-2010, 07:33 AM   #2
For about $15, you can replace it and feel safer. Either the spring is weakening or the valve opened and something got stuck under the seat. You could use the handle on the end of the valve to quickly open and shut the valve to see if it is a piece of debris holding the gate open. Be careful when doing this since you are dealing with hot water.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 12-11-2010, 08:07 AM   #3
Chris,
Do you have a small blue tank attached to the cold supply of the waterheater? Also you should check your water pressure. It is possible that the spring is weak. Also very likely it is the result of failure of the expansion tank or too much water pressure.
Work4living is offline   Reply With Quote
Old 12-11-2010, 08:20 AM   #4
Check your auto fill valve it might be stuck open continuously feeding boiler. Check pressure temp gage on front of the boiler if its near 30# it's to high. Should be around 12#
COLDIRON is offline   Reply With Quote
Old 12-11-2010, 08:22 AM   #5
Cold this is a domestic water heater not a boiler.
Old 12-11-2010, 08:36 AM   #6
Thanks Work I didn't see it mentioned any where. New glasses are in order.
Old 12-11-2010, 09:40 AM   #7
Check your PRV. Maybe it failed and the T&P is just doing it's job?
burnt03 is offline   Reply With Quote
leaking pressure relief valve on heating water boiler benjamintr HVAC 13 01-29-2011 06:32 AM
well pressure tank leak wengang1 Plumbing 16 10-07-2010 09:59 AM
Well Pump Problems dannyjoe Plumbing 6 10-01-2009 07:10 PM
Low Hot Water Pressure NOT the Valve mistervenable Plumbing 1 12-16-2008 11:50 PM
Toilet valve into wall leak. 68MHJCs Plumbing 9 11-21-2008 07:52 PM
