Leak In Plumbing Line - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-21-2011, 10:42 AM   #1
Rewards Points: 41
Leak in plumbing line
Had company come out, and was told have a leak in AC Condensate/Kitchen/Washer line.
Leak is under the slab in a hall closet... $1300 quote to repair.
If the leak is under my slab, do I even care that water is leaking out in these lines?
dbower is offline   Reply With Quote
Old 10-21-2011, 02:13 PM   #2
In my firsthand experience, that leak will likely turn into a clogged line at some point in the future, as surrounding soil is pulled into the line. Also, depending on your soil, it could cause shifting that affects your foundation.
I think you're very lucky if it is indeed under a closet and not in the middle of the den (with glued in laminate flooring) like mine was. The PO left some extra flooring, so I was able to repair it, but it was no fun fixing a missing in the middle of the room.
I'm curious what caused you to have this looked at in the first place.
Impatient is offline   Reply With Quote
Old 10-21-2011, 02:37 PM   #3
Rewards Points: 41
Actually it was foundation issues that prompted to have it looked into. But the leak is nowhere near the foundation issues... thats why I asked.
Old 10-21-2011, 04:38 PM   #4
AlbacoreShuffle's Avatar
Water will travel.
You should get it fixed asap.
AlbacoreShuffle is offline   Reply With Quote
Water supply line on the back has a leak lauraochoaanp Appliances 3 08-31-2010 06:19 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Cold Water Line Leak under Sink Greekboy Plumbing 1 06-11-2009 01:46 PM
fuel leak where filter line meets tank line sonofthetonsured Automotive Repairs 2 04-22-2008 08:11 AM
Leak on gas heater water line? darsunt Plumbing 3 04-16-2008 03:57 PM
