Leak In Outdoor Drain Running Under Concrete... - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-25-2012, 09:27 PM   #1
Rewards Points: 12
Leak in outdoor drain running under concrete...
I have a 4# drain pipe that drains a large concrete patio. The drain pipe is leaking. Is there a way to re-line the pipe instead of digging it up and replacing it entirely? It would mean busting out 8-10 feet of concrete...
Soparklion is offline   Reply With Quote
Old 05-25-2012, 09:38 PM   #2
Lightfoot's Avatar
Rewards Points: 272
Would a smaller size pipe work?
If it would, you possibly could slip it thru the existing one.
If it's not a straight run, a slightly smaller size rubber hose may work as well. It can be found in just about any size, but the bigger diameter stuff can get rather pricey. It would probably last for a few years anyway.
Lightfoot is offline   Reply With Quote
Old 05-25-2012, 11:17 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 774
yes, it can probably be lined - if there are not too many turns such as p traps
Old 05-26-2012, 07:32 AM   #4
Rewards Points: 93
How do you know it is leaking?
George6488 is offline   Reply With Quote
The Following User Says Thank You to George6488 For This Useful Post:
Ravenworks (05-26-2012)
Tips For Pouring Concrete? Root issues? Thoughts? kronic24601 Building & Construction 5 02-14-2011 06:52 AM
Crumbling Front Porch - Part 2 - The Repair jerseyguy1996 General DIY Discussions 9 04-11-2010 06:11 AM
Conduit for wiring running thru concrete foundation? Oxymoron Electrical 11 12-05-2009 07:26 AM
Sleeve options for plumbing through concrete? Bruce L Plumbing 6 06-14-2008 09:38 AM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-03-2005 10:27 PM
