Leak Near Main Supply Shutoff Valve. - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-24-2011, 10:17 PM   #1
Leak near main supply shutoff valve.
I had to turn off the water in my house tonight and noticed a small wet spot that was coming from right behind the nut on this black valve (?) above the shutoff valve. It was dripping about once a minute.
4 questions: what is this thing called (see picture), what is it for, will tightening the bolt stop the leak and will there be any bizarre consequences (e.g., reducing water pressure to the house) from doing that?
Thanks....
Leak near main supply shutoff valve.-valve.jpg   Leak near main supply shutoff valve.-valvedetails.jpg
cSquall is offline   Reply With Quote
Old 07-25-2011, 01:44 AM   #2
Rewards Points: 400
If hte leak is from the upper nut, just give it a little turn. But based upon the green corrosion, the nut on the right is leaking. Give it a turn. Don't mess with the lock nut or adjusting screw on the item to the right. That device is a pressure regulator.
fireguy is offline   Reply With Quote
Old 07-25-2011, 09:36 PM   #3
Confirming...
Thanks. I'm feeling pretty stupid now, but in matters of plumbing and electricity, I tend to be cautious, so please bear with me. The water is dripping from between B and C in the photo below. A is completely dry. Which part are you saying to give a clockwise turn to --- A, B, C, or something else?
Outside water main leak - HELP troy65 Plumbing 5 07-08-2011 06:57 PM
cost - leak on main water line and changing valve sandrashand Plumbing 13 01-15-2011 07:56 AM
Main water valve in condo shut off, but neighbors can still hear water running through pipes. cookiebird87 Plumbing 1 12-01-2010 04:43 PM
Master (water) shutoff valve rmdyjoe Plumbing 7 12-05-2008 08:55 AM
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 12:43 PM
