Leak In My Wall - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-28-2011, 11:46 PM   #1
leak in my wall
I was told my a plumber that we have galvanized and copper pipes fused together...is this possible?
The plumber did not tear down the wall, so are there tools to detect this?
Does the elevated water pressure coming into my house cause leaks?
What do i do to regulate?
Thank you for all your help, i appreciate the response.
benluz is offline   Reply With Quote
Old 01-29-2011, 07:05 AM   #2
Rewards Points: 530
Maybe he saw where the plumbing entered with gal then saw copper inside the house. If two dissimilar materials are not connected with the proper fitting, yes, it can cause leaks. These fitting prevent the two materials from having direct contact.
ledger stones on stucco wall, but wall is bowed rrauenza Building & Construction 7 05-18-2010 05:38 PM
Retaining Wall and Muddy Yard rjschwar Landscaping & Lawn Care 10 02-24-2010 12:55 PM
Removing a 4 foot opening in a load bearing wall (for fish tank) ~callie~ Building & Construction 1 07-15-2009 05:10 PM
Bathtub faucet leak in wall seabreezz Plumbing 3 02-14-2009 11:59 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
