Leak At Kitchen Faucet Spout - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-01-2011, 06:42 AM   #1
Rewards Points: 79
Leak at Kitchen Faucet Spout
I have a Price Pfister Marielle three piece kitchen faucet assembly (26-3NXX) and there is a leak at the spout (both at base and top)I have not yet disassembled the spout (I have the schematic) but aside from washers what else cold be leaking. On the schematic I see a part (971-002) just below the cap on the spot but nowhere does it ell me what this is or what it does. Suggestions please.
vabear is offline   Reply With Quote
Old 05-01-2011, 07:12 AM   #2
Leaking at the base is usually a worn o-ring. Leaking from the spout could just be a bad aerator, or the threads at the aerator are cracked.
Old 05-01-2011, 03:31 PM   #3
Rewards Points: 79
Leaking Faucet
Aerator is OK and tomorrow I will pull the faucet shroud (guess that is what you call it) off, need to use an Allen wrench to remove the Tensioner on the spout and I hope that the shroud will then pull off exposing the feed tube and all gaskets and washers. What do you think?
Old 05-02-2011, 09:53 AM   #4
Rewards Points: 79
Leaking Spout
Took cap off of spout and found a brass nut with Allen wrench center, as the spout was rocking a bit in the vertical I slowly tightened the nut to remove the play and currently the leak is no more. (film at 11:00).
Moen Kitchen Faucet Leak and Limp Handle DenfromDanbury Plumbing 8 01-02-2015 08:52 AM
Kitchen faucet splinter2 Plumbing 1 01-13-2011 11:50 AM
Kitchen faucet threads - install swivel aerator USEYOURHEAD Plumbing 2 10-09-2010 12:30 PM
Low water pressure on Kitchen faucet DIY_user Plumbing 3 01-08-2010 12:08 PM
Replaced kitchen faucet - now less hot water? sde Plumbing 5 05-26-2009 03:16 AM
