Leak Indicator Spinning Backwards - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-03-2011, 12:40 AM   #1
Leak indicator spinning backwards
The leak indicator on the water meter will spin backwards 1/2 turn or so. Is this normal?
We have low water pressure after a leak we fixed and the water company is reluctant to check the meter for problems.
whitecrow is offline   Reply With Quote
Old 08-03-2011, 02:08 AM   #2
Water Treatment
Rewards Points: 898
You turn the water off and the meter spins back ward a little?
You might put in a check valve before the meter to keep water from flowing backwards.
Akpsdvan is offline   Reply With Quote
Old 08-03-2011, 02:16 AM   #3
Yes would this be an indication that the meter is not working right?
We have very low water pressure.
Old 08-03-2011, 05:30 AM   #4
Rewards Points: 1,512
I would not worry if the tiny spinner in the meter turns back a half turn. If it went several turns or kept going then I would worry.
By the way, if there is no backflow perventer it is possible for the normal expansion of water to push some back into the water main as each new tankful of water in the water heater is heated.
AllanJ is online now   Reply With Quote
leak in cement tile roof virgo822 Roofing/Siding 2 07-23-2011 05:29 AM
Roof leak nightmare..... it won't stop amandat37 Roofing/Siding 52 04-22-2011 12:47 PM
Apartment water leak - questions haris General DIY Discussions 2 03-23-2011 07:26 PM
leak leak leak dongdong1 Building & Construction 4 01-11-2011 09:21 PM
Shower leak (what else) Old home, new owner... Rubbertree Plumbing 8 09-25-2009 01:26 PM
