Leak On Gas Heater Water Line? - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-15-2008, 11:48 PM   #1
Rewards Points: 682
Leak on gas heater water line?
I discovered a serious leak on the flexible copper cold water supply line to our main water heater. The leak seems to be coming out from just behind the fitting that screws onto the straight copper pipe.
I shut down most of the leak by tightening the fitting, but there is still a very tiny seepage, you can only feel it.
What could cause this leak? And will simply replacing the flexible line take care of the problem?
An odd note, the shutoff valve is located on the HOT water line. Which means I'm trying to figure out how to replace the leaking line without filling the entire supply system with air.
darsunt is offline   Reply With Quote
Old 04-16-2008, 06:11 AM   #2
There should never be a shut off valve on the hot line.
What kind of fitting is it? Compression? Flare?
Can you tighten it some more?
Why is there a fitting-is it a coupling?
Its really not a big deal draining the system, you simply run each tap until the water runs smoothly to bleed out any air when you're done.
Gencon is offline   Reply With Quote
Old 04-16-2008, 08:55 AM   #3
Journeyman Plumber
Ron The Plumber's Avatar
You might need to replace this line all together to fix it.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 04-16-2008, 03:57 PM   #4
Rewards Points: 682
Maybe I used the wrong term. It is the nut at the end of the copper flex line that screws into the water line. The water was leaking out of the back of the nut.
What could have caused this leak? It is possible somebody bumped the line, but it may have happened without anyone touching it. Could the flexible line have been bad, a bad washer?
Anyways the leaked stopped for now. I'll leave it alone and keep an eye on it.
Water heater problem bear1957 Plumbing 23 11-01-2007 03:53 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
Water heater leak? spydrtrbo Plumbing 1 06-29-2006 07:56 AM
Hot water heater leak? chrisintroy Plumbing 3 02-27-2006 09:13 AM
Hot water heater leak? ddasher8 Plumbing 1 07-03-2005 05:00 AM
