Leak In Concrete Tank - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-28-2011, 05:19 AM   #1
Leak in concrete tank
I use a concrete tank as reservoir for spring water. The tank has developed a leak around the house supply line where it exits the tank, probably due to the water line motion when the pump kicks on. Anyway, what can I use to stop this leak and prevent future leaks?
Toby Russell is offline   Reply With Quote
Old 08-28-2011, 07:05 AM   #2
Rewards Points: 1,216
Pictures please.
COLDIRON is offline   Reply With Quote
Old 08-28-2011, 08:10 AM   #3
Lightfoot's Avatar
Rewards Points: 272
There is a hydraulic cement product made by Euclid chemical company called "Dam-it" that i have had very good results with. It's easy to work with, very strong, and very quick to use. Once mixed, you have about three minutes to work it in place, but once it's there-it ain't goin nowhere! To achieve a little more working time, you can mix it with ice water.
http://www.euclidchemical.com/filesh...ata/dam_it.pdf
I used it to repair some leaking drain pits at a carwash. that was about 10 years ago and as far as i know, its still holding. You can go the their website or call them to see where the nearest distributor is.
If it has to do with concrete, these guys are the pros. Very knowledgeable and very friendly.
Lightfoot is offline   Reply With Quote
The Following User Says Thank You to Lightfoot For This Useful Post:
Marbledust (08-28-2011)
High Rise Building methods - US versus Oz - Steel versus Concrete Jado Off Topic 17 09-15-2011 08:47 PM
Lawnmower has leak in gas tank furchild Landscaping & Lawn Care 11 05-19-2011 04:04 PM
Tips For Pouring Concrete? Root issues? Thoughts? kronic24601 Building & Construction 5 02-14-2011 06:52 AM
Stained concrete floor showing water leak Rox Plumbing 0 09-27-2010 03:33 PM
Got a leak in between concrete & T111!!! DIYtestdummy General DIY Discussions 4 06-30-2008 03:20 PM
