Old 11-19-2009, 12:33 AM   #1
Leak in Cast Iron? Pipe under toilet...
I noticed that whenever the toilet's flushed, a pretty bad leak develops into the basement. I dried off the pipe, installed a new wax seal on the bowl and flushed - still bad. Dried it off again, stood under the pipe, son flushed it, and the leak comes from what appears to be a 2-3 inch "crack" in the piping. If it was coming from a bad seal, it would originate from where the bowl meets the floor---right? I see the crack leak - so I am pretty sure this is what it is - a crack!
It's a fairly large pipe that I believe it cast iron - certainly not PVC, copper.
I have heard JB weld may be perfect for this type of repair. I imagine that calling in a pro would cost a ton and I am looking for the best long term DIY solution.
terrapin88 is offline   Reply With Quote
Old 11-19-2009, 06:29 AM   #2
Master General ReEngineer
Ayuh,... It's cast iron,+ it's Rotten....
Replacement with PVC is the proper Long term fix...
Old 11-19-2009, 06:30 AM   #3
JDC
Plumbing Contractor
JDC's Avatar
Short term: give the jb weld a try.
Long term: that section needs to be replaced. Cast iron rusts from the inside out. Plug up that "crack" and it most likely will start leaking elsewhere at some point. Cant say when it will happen....could be a few weeks, couple of months or maybe even a year or two later. Or...you might get lucky and the thing will outlast both you and I. It really should be replaced at some point but the jb weld might be just what you need to buy some time.
JDC is offline   Reply With Quote
Old 11-19-2009, 11:37 AM   #4
I figured the JB would be short term - the section of pipe that;s rotten is actually a piece that looks like it could be"unscrewed", not cut or anything. how would I even begin replacing that section with PVC?
Old 11-19-2009, 12:45 PM   #5
I have not encountered threaded cast iron. This could be galvanized steel pipe. patching either product will be short term. Cast iron cracks will "run" and get worse. There are couplings made to transfer from cast iron and steel pipe to PVC pipe. Most Home Centers carry them. I like No-hub brand and Fernco.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 11-19-2009, 12:55 PM   #6
galvanized steel - the crack is on the elbow and there are definitely 2 threaded sections I can ee - one to the floor above and the other to the drain pipe going vertically to the basement floor. is JB Weld th best thing I could try or is there something better? also, how would I even begin removing that section?
Old 11-19-2009, 01:32 PM   #7
One thing you should do before putting JB on the crack is to drill small (1/8 max) crack "stopper" holes at the end of the crack. This relieves the stress that is present there. I do agree the JB is likely a short term fix, but if it is easy to get at this spot, you can keep an eye on it. The corrosion of the pipe will continue and you should be looking into a PVC replacement.
LeakyMike is offline   Reply With Quote
Old 11-19-2009, 05:59 PM   #8
union journeymem plumber
130 plumber's Avatar
Better yet can you post some pictures on whats going on
130 plumber is offline   Reply With Quote
Old 11-19-2009, 06:09 PM   #9
more than likley what he was trying to say is that the cast iron pipe tee was a tap tee fitting which allows you to lead in both hub and spigot then tread in a nipple from the side of the tee
Old 11-19-2009, 06:45 PM   #10
well i just did the repairs - i was up till 3 last night just cutting away at wood that was concealing the whole pipe - amazing. anyway, i sanded the pipe - used acetone to clean it and prep it, did the jb weld. i bought some pipe wrap - how long should i wait before applying the wrap over the jb weld? and yes, i drilled 2 holes at either end of the crack.
Old 11-19-2009, 06:46 PM   #11
and by the way - what would a replacement by a pro run me - approx.? im in chicago...
Old 11-19-2009, 06:54 PM   #12
Its hard to say with out seeing what needs to be done.
More On This Topic
We've all heard the frantic request from the bathroom to bring the toilet plunger before the toilet runs over. All of us will cope with a toilet malfunction at one time or another. Some repairs are best left to the experts, but many fixes are simple once... Read More »
Today we are replacing a disabled toilet. It leaks and it also leaks down at the base where it’s cracked at, so we’re just going to replace the whole entire thing. If you buy a toilet that is- it’s called a toilet in a box. It has... Read More »
Hi this is Jon on behalf of Expert Village in this video clip we will be diagnosing our problem. In this set of video series we would be working on this toilet. Now the problem with this toilet is about every 10-15 minutes it would run or the tank will... Read More »
How to Remove a Toilet
How to Remove a Toilet by Expert Village
Today we’re replacing a dead toilet, one that leaks real bad. What we’re going to do is after you clean the area and get everything all prepped, you’re going to disconnect the water supply. We already have the water turned off. You just... Read More »
Hi! My name is Cathi Pare with the City of Santa Barbara Water Resource Department speaking to you today for expertvillage.com. We are continuing on our little quest of how to fix the leaks in your toilet. Early, earlier conversation we talked about the... Read More »
stuck iron pipe on oil tank vent wrybosome Plumbing 3 01-13-2009 10:43 PM
Pipe knocking when toilet flushed guykovera Plumbing 5 09-27-2008 09:17 PM
Vent Pipe Leak romeguy1 Plumbing 9 12-11-2005 01:08 AM
Leak at flange and drain pipe tallycat77 Plumbing 1 07-26-2005 09:32 PM
Toilet; Cistern to Toilet pipe ( Complete Novice) broke1973 Plumbing 1 07-15-2005 09:34 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
