Old 01-16-2013, 08:30 PM   #1
Leak in cast iron pipe..
I have an old iron pipe coming up into the plumbing for the laundry sink...it's leaking at the base where it comes up from the floor. Is there a kind of cement or something I can use around the bottom for a water tight seal? Thanks.
KDOC is offline   Reply With Quote
Old 01-16-2013, 08:35 PM   #2
Roofmaster
Pictures?
" A lot of men build things, and a lot of things fall down "
Old 01-16-2013, 10:24 PM   #3
Any iron or stell pipe is going to leak and plug up at some point and need to be replaced with PVC.
You can patch all you want to but it will fail again at some point, not a good thing when it's under the slab.
I think there is a hole in cast iron pipe from toilet cprice Plumbing 5 09-18-2012 09:51 AM
Rusted cast iron vent pipe bluecruzer Plumbing 23 02-21-2012 11:25 PM
Build up in cast iron pipe bend -> new high pressure toilet to fix? VTJeff99 Plumbing 3 02-09-2012 02:05 PM
Help me! Cast Iron Leak (Picture) meandiet Plumbing 8 08-14-2011 05:41 PM
Cast iron pipe broken? tervic Plumbing 6 02-18-2009 07:23 PM
