Old 06-22-2012, 05:06 AM   #1
leak below upstairs bath tub
Water leaked through my downstairs smoke alarm after draining a full bath tub directly above this alarm. I opened the drywall and can see the pipes, but they do not leak now. There must be a drainage problem, but I'm am at a loss! Any ideas would be greatly appreciated.
mykeyj is offline   Reply With Quote
Old 06-22-2012, 07:05 AM   #2
Super Moderator
Most common tub leak areas--
Overflow gasket not set properly.
Bad tile/tub connection--failing tile job
Water on floor due to bad door--shower curtain---
Leaking shower arm inside wall
bad gasket on mixer cover plate.
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
goosebarry (07-07-2012), mykeyj (06-22-2012)
Old 07-07-2012, 08:02 PM   #3
It was the overflow gasket... thanks again!
The Following User Says Thank You to mykeyj For This Useful Post:
oh'mike (07-07-2012)
Old 07-07-2012, 08:21 PM   #4
Super Moderator
I learned that one the hard way----
Old 07-07-2012, 10:28 PM   #5
I had all of those in one year plus "bad main drain seal" and "corroded brass drain pipe" except "Bad tile/tub connection--failing tile job", and that's only because we don't have tile.
goosebarry is offline   Reply With Quote
Old 07-07-2012, 10:39 PM   #6
sacramento plumber
wctekkk's Avatar
Location: born and raised in San mateo ca. living in Sacramento Ca for 3 years now.
fill the tub till middle of overflow easier w/2 people slash water w/hand or cup all around the overflow #2-check for leaks from below #3-pull stopper check for leaks from below. Basic test that's if you had only taken a bath.if no leak shows up then it's tub valve ,tub spout,caulking.tub surround,water splashing out of tub.
wctekkk is offline   Reply With Quote
Old 07-08-2012, 12:05 AM   #7
Supply pipes don't always leak when water is shut off..try running the tub/shower separately while observing..a pin hole leak may take several minutes to show up..make sure you dry off the area, piping as much as possible first and use a good flashlight to spot the leak...same procedure while draining the tub
techpappy is offline   Reply With Quote
Old 07-18-2012, 10:06 AM   #8
so, how did things work out?
Tags
leak below tub
Roof leak nightmare..... it won't stop amandat37 Roofing 52 04-22-2011 01:47 PM
Apartment water leak - questions haris General Discussion 2 03-23-2011 08:26 PM
Freon Leak captainron19 HVAC 3 04-16-2010 05:30 PM
Water Leak Detection AppleMac*Fit Plumbing 16 12-29-2008 07:30 AM
Switching the Plugs in Bath Fan/Light MrBill_DIY Electrical 3 12-01-2008 07:45 PM
