Leak Before Main Shutoff In Basement - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-17-2013, 02:51 PM   #16
Rewards Points: 402
I think you might have some trouble soldering to that pipe, especially if it's not perfectly straight. I would use a compression or flare fitting. They are rated to 500psi to pressure isn't an issue. I would think tightening up the fitting would fix the problem though.
taylorjm is offline   Reply With Quote
The Following 2 Users Say Thank You to taylorjm For This Useful Post:
fetzer85 (04-17-2013), oh'mike (04-17-2013)
Old 04-17-2013, 04:21 PM   #17
Always learning...
fetzer85's Avatar
Rewards Points: 262
Alright then I'll get the dirt out, see what style wrench I need, get it, turn off the main, try to tighten up the existing fitting, turn the water back on...and of course cross my fingers.
Oh I should prob have a new fitting too in case tightening up the existing one doesn't work.
fetzer85 is offline   Reply With Quote
Heat for a basement with Pellt Stove on Main Floor magnum44 HVAC 1 11-20-2011 08:55 AM
Basement Leak Problem along Brickwall/Driveway side Firehawk734 Building & Construction 1 08-16-2011 05:20 PM
Locating Main Drain Line in Basement koz123 Plumbing 6 02-11-2011 09:41 AM
Leak in basement? Jaye11 Plumbing 3 09-02-2010 02:43 PM
Water leak in basement john4153 Plumbing 5 08-03-2010 10:26 PM
