Leak Around Relief Valve Area - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-22-2012, 01:41 AM   #1
Leak around relief valve area
Hi everyone. I wanted to know if anyone has any experience with this leak. It's a rheem 75 gallon water heater and just noticed that it was leaking around the relief valve area. Then I made the mistake of opening the relief valve to drain some water and now it's leaking down the relief valve pipe.
I've attached a picture and hopefully someone can tell me if this can be fixed or get a new water heater. Thanks!
Leak around relief valve area-wp_000973.jpg   Leak around relief valve area-wp_000974.jpg
ibuyufo is offline   Reply With Quote
Old 09-22-2012, 09:49 AM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Relief valve = 10-20 bucks
Water heater = ~350 bucks
I'd try swapping the relief valve first.
Normally i'd say just tap on the top of the stem of the thing and it should seat and stop leaking, but since it appears to be leaking around the threads, it should be pulled out and reinstalled anyway. Might as well get a new one.
I'd probably take the old one out before you go to the store to make sure you get one the right length.
Journeyman Plumber
The Following 2 Users Say Thank You to Alan For This Useful Post:
ibuyufo (09-22-2012), plummen (09-23-2012)
Old 09-22-2012, 10:13 AM   #3
Thanks for the advice. I will try that first and I do hope it's just that!
Old 09-22-2012, 10:21 AM   #4
Rewards Points: 13,732
Your going to have to shut the heater off, shut the water off going to it, relieve the pressure by opening up a faucet and drain some of the water out of it be removing it.
Old 09-22-2012, 11:25 AM   #5
Thanks! I'll make sure to do that before I take it out. Will there be a lot of water coming out from the relief valve after I do all the steps above or will there be none? I am planning on taking the relief valve with me to get the exact size.
Old 09-22-2012, 03:32 PM   #6
Doing it myself
Alan's Avatar
Drain some of the water out of the tank first, and then you won't have any water coming out of the relief valve :D
Journeyman Plumber
The Following User Says Thank You to Alan For This Useful Post:
ibuyufo (09-23-2012)
Old 09-23-2012, 12:51 AM   #7
Thanks everyone for all your suggestions. Turns out I needed to replace the water heater.
pressure relief valve leaks f9 flier Plumbing 21 06-14-2011 06:55 PM
Delta scald guard shower valve leak pdamania Plumbing 1 03-08-2011 05:45 PM
Leak from pressure relief valve CHRIS650 Plumbing 6 12-11-2010 08:40 AM
Vacuum relief valve? walker44 Plumbing 10 08-30-2009 04:33 PM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 10:02 AM
