Old 10-25-2009, 07:44 PM   #1
Default Lead Solder on baseboards
Is it alright to use leaded solder on a hydronic baseboard system. I have to make some repairs that are close to existing joints and I wanted to use leaded solder for the lower melting point. Am I thinking correctly or is there something better to use?
jerryh3 is online now   Reply With Quote
Old 10-25-2009, 07:50 PM   #2
Master Plumber/Mechanical
I have always use lead free. Seems to flow better. Make sure you clean and use flux.
You may have to drain the system to heat the metal
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Arcoaire and Trane Dealer
Old 10-25-2009, 08:03 PM   #3
I used lead free today and it seemed to work alright. The next section I need to fix, I'm getting closer to some existing joints and I just don't want to compromise them. System is drained so no problems there. This project is reminding me how much I dislike plumbing. Only one burn today though.
Old 10-25-2009, 08:27 PM   #4
JDC
Plumbing Contractor
JDC's Avatar
As long as you are not soldering on a potable water system then 50/50 solder (contains 50% lead) is fine to use. I use it often when soldering copper DWV systems.
JDC is offline   Reply With Quote
More On This Topic
Learn materials needed for silkscreening at home and how to screen print a shirt in this free video on silkscreening, or screen printing, clothing. Read More »
Hi! This is Diana for expertvillage.com and today we are making a copper plant hanger from copper refrigerator tubing so I would like to show you all the materials that you are going to need to make this particular garden hanger. I have some half inch... Read More »
Sometimes adult children are faced with the difficult realization that a parent is not able to keep up with his personal and financial affairs any longer. Becoming a guardian or conservator of your parent, however strange it seems, could be necessary in... Read More »
How to solder 2mm nuts DIYCUB Plumbing 4 04-09-2009 01:06 PM
Help removing baseboards without damaging sheetrock Lighthearted Painting 3 04-05-2009 07:52 PM
When soldering copper, what causes the solder not to "suck in"? Piedmont Plumbing 10 10-25-2008 10:59 AM
Solder for hot water heating system junkcollector Plumbing 2 09-12-2008 08:09 PM
Click lock floors under baseboards ? bcarwell Flooring 4 03-31-2008 01:03 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
