Lead Pipe Cracked At Concrete - Fix Possible? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-03-2010, 07:53 PM   #1
Lead Pipe Cracked at Concrete - Fix Possible?
1950's home. Contractor was working on kitchen and thought there was a small crack in the lead pipe. He pushed it to see and I think he created a small crack in doing so.
The pipe comes up out of the solid concrete slab that our home rests upon. Is there a way to fix this easily? What would be a quick fix, and what would be a "proper" fix? Estimates on proper fix costs would be appreciated.
Unfortunately, we just got the cabinets, counters, all that stuff in so this is a real bummer.
Scarlo is offline   Reply With Quote
Old 01-10-2010, 06:47 PM   #2
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
is it a supply or waste line?
plummen is offline   Reply With Quote
Old 01-10-2010, 09:47 PM   #3
Waste line.
Old 01-10-2010, 10:09 PM   #4
plummen's Avatar
how about a picture?
Old 01-10-2010, 10:20 PM   #5
plummen's Avatar
im guessing its gonna be about impossible to wipe some lead in there,can the cracked area be roughed up enough to repair with epoxy as temp fix if crack is above floor line? yeah i know notmy 1st choice either but sometimes you have to do what you have to do!
Old 01-10-2010, 11:12 PM   #6
Hard to get pics because it's under the new cabinet, back near the wall, with the crack on the backside. It's right at the base of the floor though...
I'll give the epoxy a shot. I'll let you know how it goes!
Old 01-11-2010, 05:00 PM   #7
Rewards Points: 562
Is that a crawl space or full basement under this kitchen? Take a hint from the Holmes on homes show and 'Just do it right'.
I can see lead in exposed ares,but it SHOULD join cast or similiar before it exits far. Replacing that lead part isnt a big project. 2"PVC is pretty cheap,pipe and fittings
4just1don is offline   Reply With Quote
Old 01-11-2010, 06:48 PM   #8
thanks guys - the epoxy seemed to work. hopefully it bonded and stays put for a long, long time!
Old 01-11-2010, 07:02 PM   #9
Licensed Engineer
Rewards Points: 171
My guess is that the pipe is galvanized iron, not lead
Galvanized pipe was commonly used in the 1950's for small diameter waste lines. Unfortunately, it is not as durable as the larger cast iron pipes it connects to.
This would be a good time to completely remove the old galvanized pipe - if at all possible - as it is certain to fail and leak.
MI-Roger is offline   Reply With Quote
Old 01-11-2010, 07:44 PM   #10
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
My 1954 House had the upstairs bathroom 1-1/2" Galvinized sink drain routed down, then through, a 15" horizontal run and then another 4' vertical drop (all with 90 deg elbows) before it hit the cast iron line. One aggressive sink routing opened a leak in the horizontal run.
1-1/2" ABS with sweep bends solved the problem
Lead Pipe Cracked at Concrete - Fix Possible?-galv-drain-leak.jpg   Lead Pipe Cracked at Concrete - Fix Possible?-imgp0225.jpg
Disclaimer
& Stay Safe
.....Bob Lavery
Old 01-11-2010, 08:39 PM   #11
plummen's Avatar
that is ilegal in most areas .thats a lot of weight from that galvanized pipe pushing down on that abs unless you run the abs all the way through the roof/vent
Old 01-11-2010, 09:14 PM   #12
Rewards Points: 562
nice job Pali Bob,,,that has to be better than that galvanized nightmare you had. Is there weight pushing down on that coupling or is bends or fittings/flanges etc holding it up?
original poster-take note of what Bob did and do likewise or your sure to follow same result. IF its galvanized or leaded,, if you could see inside that pipe and see how plugged they ALWAYS are,,you would see the point!! "HERE" we dont use much black abs,,,we use white PVC(with purple primer/glue),,,either will work. Plastic dont plug up like iron or lead.
Old 01-11-2010, 09:31 PM   #13
plummen's Avatar
purple primer is for use on underground work so inspector can see pipe is primed without climbing in ditch,clear primer is for above grade work.same stuff,just doesnt have nasty purple dye in it.
Concrete Repair Help / Contractor Problems thp Building & Construction 12 09-24-2009 02:01 PM
Cutting concrete to hide an a/c drain pipe? CooperChloe Building & Construction 3 02-04-2009 09:28 PM
why not bury copper pipe in concrete ??? yesitsconcrete Building & Construction 2 02-03-2009 07:51 AM
Cracked PVC fitting in concrete DJupin Plumbing 6 07-29-2008 04:12 PM
drain pipe depth under concrete amakarevic Plumbing 4 07-27-2007 08:35 PM
