Lead Bend - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-24-2013, 08:54 PM   #1
lead bend
is it better to use cast iron or pvc to replace a lead bend
peterbrookl is offline   Reply With Quote
Old 02-24-2013, 09:20 PM   #2
Roofmaster
Rewards Points: 2,172
DO you mean a lead closet bend? WTF is a Lead Bend???
Old 02-24-2013, 09:42 PM   #3
Rewards Points: 6,652
Most of that old lead is inch and a quarter, inch and a half. Really need a picture of what you are talking about, due to most lead piping was used for kitchen vent, waste drains for bath & kitchen sinks.
Post a picture of what you are talking about. As for the answer, majority of the time, PVC. Cast Iron work is becoming a lost art.
Old 02-24-2013, 10:04 PM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 436
They will both last you another 20 yrs. at least. CI is quieter but not readily available at hardware stores for the DIY'er. You can find the plastic parts easily and most residential plumbing is now done in plastic.
Adapting to the existing CI hub will be your biggest hurdle.
Old 02-24-2013, 11:21 PM   #5
Master Plumber
Javiles's Avatar
Rewards Points: 986
Especially if its spun off a sanitary tee.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 02-24-2013, 11:30 PM   #6
much easier to use PVC
Replace / add flange on lead lip at bend ZMan9854 Plumbing 3 01-29-2013 11:10 PM
Resetting my toilet after tile install... MisterSteve Plumbing 24 01-11-2013 01:45 PM
Total Degrees of Bend in Underground PVC Conduit tedallen Electrical 12 03-29-2012 09:02 PM
Lead Drain Pipe Project Turbo98 Plumbing 33 01-30-2011 12:27 PM
4" PVC to 4" Lead Bend solidhomes Plumbing 0 07-20-2010 01:36 PM
