Old 09-04-2011, 07:31 PM   #1
leach line clog
we just had the septic pumped solid/gray and the one with the grinder pump. the pumped worked but very little if any went past the first 6 inches of pipe that went to the field. is there a cheap way of unclogging the pipe
redneck420 is offline   Reply With Quote
Old 09-05-2011, 07:15 AM   #2
leach line clog
Jetter!
plumberinlaw is offline   Reply With Quote
Old 09-05-2011, 08:52 AM   #3
Civil Engineer
leach line clog
Redneck, your post sounds like a tone poem, or perhaps a really bad rap song, or maybe what you get if you translate English into Japanese and then back to English using a computer, or maybe it is some sort of southern style haiku. Maybe you could rewrite the post with some punctuation so I can understand it? Or maybe it is clear to everyone else.
The Following User Says Thank You to Daniel Holzman For This Useful Post:
tpolk (09-05-2011)
Leaking cast iron drain pipes + roots in 4" main line aminus21 Plumbing 5 09-25-2010 11:21 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
Natural gas line????? figs Plumbing 1 06-14-2009 02:13 PM
electric line and gas line couch potatoe Electrical 17 09-30-2008 11:43 PM
Condensate Line schott HVAC 17 06-02-2008 04:16 PM
