Leach Field Issues - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-16-2010, 06:09 PM   #1
Leach field issues
My dog dug up a couple huge holes on the leach field. Then they were just filled in with soil. When they were filled in they were full of water and now that they are filled in weeks later there is water seeping up from the ground and a bad smell occasionally. Where should I even start with this?
blegace is offline   Reply With Quote
Old 07-16-2010, 10:07 PM   #2
Rewards Points: 1,448
Had you gotten a tremendous amount of rain at the time? That could saturate the ground and prevent the outflow from the septic tank from being properly and correctly and normally absorbed.
Most likely there was already a problem with the leach field, having nothing to do with your dog.
There is a slight chance that the kind of dirt you refilled the holes with got into the leach field pipes and clogged them.
Old 07-17-2010, 01:54 PM   #3
Thanks that makes me feel a lot better because we have had quite a bit of rain lately and with the high humidity not allowing evaporation as good and the fact that I just found a leak in my toilet sending water down the drain constantly (which I just fixed) I'm hoping it will clear up and get back to normal!
How do i fix/install septic tank drainage field? vcordon Plumbing 10 06-15-2010 11:20 PM
Septic Efluent Leach Field Docfletcher Plumbing 9 01-10-2010 08:47 AM
Septic and leach field questions rockwilliamson Plumbing 7 01-08-2009 07:28 PM
Septic and leach field design questions Boss281 Plumbing 6 10-01-2008 08:39 AM
